Old 10-19-2004, 08:08 PM
TouGer
gas type?
Hello, i'm wondering what is a good gas type for the svx... im a newbee for svx... well what do y'all think????
Old 10-19-2004, 08:27 PM
n00b on demand's Avatar
Nothing lower than 91 octane. I always use shell or getty. Mostly Shell because its 93 and full service
Old 10-19-2004, 08:35 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I concur. I also like Mobil gas and Chevron.
If you invest in the Stage 1 chip from ECUTune, you can wire it to allow you to use regular 87...
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-20-2004, 08:45 AM
rmjjensen's Avatar
rmjjensen rmjjensen is offline
Send a message via AIM to rmjjensen
I like Amoco or Mobil ....nothing but the best - highest octane. I usually fill up around 15 gallons for a whopping $30+. We've got this 18.5 gallon tank but I've never filled up past 16 gallons ....it's amazing because the low fuel light's on and it looks like the needle is ready to fall off.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing
5-Speed Status: DONE!
Lambo Door Status: On hold but will be a success
04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk.
The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash
Old 10-20-2004, 08:53 AM
Whoru465's Avatar
Whoru465 Whoru465 is offline
The name's...
Send a message via AIM to Whoru465
Always use Hess, cause its the cheapest 93 around here. I can fill her up completely for around 24 bucks. I guess I'm luckier than a lot of folks. Got to cut down on my driving though...
-Mike
'92 Pearl LS-L (sans Spoiler) #0993 Mfg. 5/91
"It says here, 'Breakfast any time'...
That's right...
In that case, I'll have the pancakes in the Age of Enlightenment..."
Old 10-20-2004, 08:55 AM
Sidewinder's Avatar
Sidewinder Sidewinder is offline
Send a message via AIM to Sidewinder Send a message via MSN to Sidewinder
Everyone is right. It says "premium fuel only" for a reason. The higher octane allows for a slightly higher compression ratio. That creates more power. Also, putting anything below the recommended 91 will result in premature detonation which is not good. It leads to power loss and the engine is not designed for that.
Ninety one and higher baby. Yeah. --Austin Powers on the SVX?
Eric
1994 Bordeaux Pearl SVX LSi
"The SVX — Where, they wondered, do you put the kayak?"
Old 10-20-2004, 09:04 AM
Invisible avatar
Cool
I don't care what the "brand" fanatics say, buy any juice, 91 octane or above & you'll survive nicely.
Ron (buying off-brand stuff since 1957).
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 10-20-2004, 09:23 AM
dcarrb dcarrb is offline
In day-to-day driving I top-off at between one-half and three-quarters of a tank and alternate between premium (93 octane) and midrange (89). There's no benefit in paying extra for straight premium, nor in shopping by brand.
dcb
Old 10-20-2004, 03:09 PM
Wiz Wiz is offline
Send a message via ICQ to Wiz Send a message via AIM to Wiz Send a message via Yahoo to Wiz
I've been running 87 for a few weeks now. I get about 1-2mpg less. So it may not be worth it but it works none the less. Assuming you have Stage I. You would not want 87 in your SVX otherwise.
With a $.20 difference between 87 and 93 I'm only going be using 87 until 93 goes down a bit.
Green 1994 SVX LSi - Totaled by a plow. RIP
Bordeaux Pearl 1994 SVX LSi - 182k
Old 10-20-2004, 06:07 PM
SVX_MY_BABY's Avatar
87 is a no no. If I remember correctly you may over heat. Has to do with the detenation/octane thing. The onboard computer adjusts to the fuel on board, so constantly changing fuel may not be a good thing either.
On a diff. note: If you are in the east ie Maine, New Brunswick, Nova Scotia, the best fuel is Irving. Simply because it is the CLEANEST fuel made. They did a mega up grade to produce low/no sulpher gas. Esso has just started a maga refit of their refinery here to change over. Personally I buy the cheapest, usually Esso (Exxon for our southern bros.)
Old 10-20-2004, 09:42 PM
Phoenix_3737's Avatar
Phoenix_3737 Phoenix_3737 is offline
chevron with techron, or shell with v-power only in my car....
1994 Pearl LS Black top ( The Penguin)
"was" The only man alive who drives a "Suba SSV".......according to my insurance company
***sold***
"was" The Only Subaru Svx Owner in Laredo Tx., or maybe atleast only owner registered here....
http://www.cardomain.com/id/phoenix_3737
Old 10-21-2004, 05:21 AM
I run Citco 93 octane.....
Old 10-21-2004, 09:24 AM
lechnoid
all major brands of automotive fuel are made by 2 or 3 companies. but brand does matter, as they all incorporate their own additives. general rule of thumb is the more expensive the gas, the more additives. the more additives, the better the gas.
what compression do these things run to require premium gas?
Old 10-21-2004, 10:02 AM
SVXer95 SVXer95 is offline
Word to Yo Motha
10:1 and I disagree with your above statement. Gas is gas. Most of the time you aren't going to be able to tell between one brand and the next. Always run 91 and above.
Also, more additives isn't always better.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 10-21-2004, 11:28 AM
lechnoid
i agree, not always. most major brands have good additives though. it's hard to find out what exactly a company is putting in, but overall, major names can be trusted.
it's the "i want to save $0.04/gallon on gas by buying from a cheapo station" sort of gas that'll get you in trouble.
