Old 09-26-2004, 02:41 PM
mysvxrocks's Avatar
mysvxrocks mysvxrocks is offline
Im REALLY addicted! CANT STOP!
Send a message via MSN to mysvxrocks Send a message via Yahoo to mysvxrocks
All Problems Suck
Well now I hate this..... The transmission stays in one gear, The rear wheel bearings are dead, and there is a gasket leaking oil onto the exhaust so after 50 miles it starts to smoke. I dont know how long it will take me to fix it all but I will soon. ~Dennis
Old 09-26-2004, 02:43 PM
Knightwulf's Avatar
Knightwulf Knightwulf is offline
Ouch! Sorry to hear it mate.. A sick SVX is never a happy thing...
Glad to hear you're going to repair her rather than part her, though.
Old 09-26-2004, 04:58 PM
n00b on demand's Avatar
The transmission doesnt shift at all? If its first gear then you might need a brake band adjustment. I think its 150 at the dealer. You can do it yourself but its kinda difficult.
Old 09-27-2004, 05:21 PM
Which gear is it stuck in?
Old 09-27-2004, 07:17 PM
mysvxrocks's Avatar
Gear
I dont know..... To get it going you have to rev it to 2000 and while going 60 MPH its at about 3-3.5 thousand rpms so I dont really know? ~Dennis
Old 09-27-2004, 07:57 PM
Re: Gear
Hmm that sounds really odd.
Old 09-28-2004, 06:24 PM
Sounds like 3rd. Check your TCU under the dash and if possible replug each connection to it (3 of them I believe).
I may be wrong but I thought I read recently that the 4EAT will only operate in 3rd gear with the TCU disconnected.
Other things to test are if you can pull any codes from the TCU. Even if only to get the "all clear".
If nothing else then replace the TCU with a known working one. I'm sure you will be able to find a donor TCU from someone here.
Old 10-02-2004, 10:36 PM
mysvxrocks's Avatar
I looked at the TCU and un hooked it all and re-hooked it back up. The problem is still there, however If I leave the TCU un-hooked then the trans works in ALL of the gears but it still wont shift. ~Dennis
Old 10-05-2004, 05:53 PM
I would definately try another TCU then.
Old 10-05-2004, 06:45 PM
Matthewmongan's Avatar
Matthewmongan Matthewmongan is offline
no limitation as limitation
well i wouldnt say that its the TCU just yet. ever time my tranny goes those are the symptoms.
