Old 09-12-2004, 02:01 AM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
Guess who trapped a 16.577
ME!!! I'm so freaking happy. Last time I ran my car, I was running 17.04's and now I'm running 16.5.
When I took the run's tonight, my car set up was totally different. I had done the resonator "induction" mod, throttle line mod, and a different filter for tonight and I must say that the SVX was in its prime. I also took out the rear seat bottom, spare tire, jack, subwoofer, and anything else that could add weight.
Here is a break down of my fastest run.
R/T- .120
60 ft- 2.497
330 ft- 7.062
1/8 mile- 10.774 MPH- 67.09
1000- 13.913
1/4- 16.577 MPH- 84.45
All in all it was a good night with temps in the low 70's and around 30% humidity. I'm happy with the results and kicked a lot of tail losing only one race to a VTEC Accord that my buddy was driving.
Keith
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 09-12-2004, 02:22 AM
SVXXVS
It was a very impressive run!
It almost brought a tear of joy to my eye!
Congrats Keith!
~Kyle~
Old 09-12-2004, 11:31 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
That's awesome Keith! 16.5 is a good time for an SVX in the 1/4 mile.
Couple questions:
1) How did you launch the car?
2) What pressures are you running in your tires front & back?
3) When are you going back for more?!
-Chike
P.S. Drag racing SVXers are waaaay cool!
2006 Steel Gray WRX TR (sold)
Old 09-12-2004, 12:53 PM
HighwayUFO's Avatar
Well, Chik Chik, maybe I want to keep a few secrets and tricks up my sleeve.
I would stage up, and mash on the brakes as hard as I can because they just don't grab like they used to. I have always liked the cars acceleration at 2000 RPM, so that is where I launched at. As soon as that last light turns yellow, I hammer the gas pedal and by doing so throws the car into power mode making sure I won't shift at any RPMs below 6K.
In the front tires I was running the opposite of stock pressure. What ever the reccomended tire pressure in the front is, I ran that pressure on the back tires and vice versa.
I'll be going back for more after I get my wheel bearings and brakes fixed.
Keith
Old 09-12-2004, 01:01 PM
Chiketkd's Avatar
Thumbs up
Keith,
Since our cars are automatics and have a 2500rpm stall, we may actually get better times by running more pressure in our tires to reduce the contact patch area.
When I did my 1/8 mile runs last weekend, I ran 33/29 in my tires, but yesterday I adjusted them to 40/36 per the 'Performance Tire' thread. These pressures will ensure that a more flat contact patch rests on the ground and will net a slight improvement in times as your rolling resistance is reduced...
-Chike
P.S. BTW, a 2000rpm launch is good as you start off higher in the power band!
Old 09-12-2004, 08:46 PM
AppStateSVX's Avatar
AppStateSVX AppStateSVX is offline
Mountaineer
Send a message via AIM to AppStateSVX
what year / model was the Accord, Last Time I raced someone, it was a 2000 Accord V6, but it was an automatic, still beat him by 3 car lengths though....... CONGRATS though, that is a REALLY good time, keep us posted when you get everything fixed, it'll probably be quicker none-the-less. Did you use your Nitrous?
1992 Midnight Black LS-L - Sold 3/3/06
1991 Toyota MR2 - Sold 11/27/07
1992 BMW 325i
- Tokicko Suspension
Old 09-13-2004, 02:09 PM
HighwayUFO's Avatar
Bottles are for babies. But if I had nitrous, I would use it. Actually, I had a "little person" in the trunk with a mouth full of laughing gas and when I told him to blow, the car would rocket ahead for about half a second.
The Accord was a '99 3.0 VTEC Automatic. He had some mods done, oh well. He won the race but the time slips say that I'm FASTA!!!
Keith
Old 09-14-2004, 05:10 AM
mikecg's Avatar
mikecg mikecg is offline
Strange
Is everyone running in the high 16's in stock form??
I took mine to the Nopi Nationals in MD a week after I bought it. Out of 2 runs my worst was 16.104 at 89MPH. Although I'm a lighter FWD model. It was completely stock.
Old 09-14-2004, 06:23 AM
Bwana's Avatar
Bwana Bwana is offline
*Special* Member
Send a message via AIM to Bwana
My white car ran 15.7 completely stock...so, uh, yeah. My red one ran 15.9, but it needed an oil change, new plugs, and a different driving style then the white one, which i didnt figure out until after i left...
[/COLOR][/COLOR]-Scott My Locker
2014 Grey Ford Fusion 2.0 EcoBoost Bought: 12-5-14
2005 Silver Legacy GT Ltd 5mt. Bought: 3-3-07 Sold: 12-5-14
1996 Brilliant Red L (AWD). Bought: 6-14-04 - Sold: 3-3-07 - 15.370 @ 89.65
1992 Claret/black LS #4086 (GF's). Bought: 6-30-04 - Sold: 7-29-07
1994 Pearl White LSi Bought: 2001? Sold: 2004?
Old 09-14-2004, 04:38 PM
Chiketkd's Avatar
Re: Strange
The fwd drivetrain layout is more efficient than awd. In general from the numbers I've seen posted for stock SVXs, most of our cars will run between 15.6-17.0 secs depending on trim level (i.e. weight) and air temperature.
The LSi/LS-L models are fully loaded with leather, sunroof, etc and tip the scales 100lbs heavier than the L/LS models. FWD models are even lighter still...
So if someone with a 3600lb LS-L model, has an additional 100lbs of speaker equipment added to their car, goes to the drag strip, a high 16/low 17 sec pass will probably result.
Another big factor is air temperature. A 16.5 sec car in mid 70* weather, will probably be in the high 15's if the temps were in the low 40* range...
-Chike
Old 09-14-2004, 09:27 PM
HighwayUFO's Avatar
Let's also not fuhgeddabout sea level playing a big factor in 1/4 mile times.
Old 09-14-2004, 09:33 PM
Chiketkd's Avatar
Good point. Altitude can play a major factor in your final elapsed time.
-Chike
