Old 09-17-2006, 12:01 AM
kuroneko_sama's Avatar
kuroneko_sama kuroneko_sama is offline
aka sir_romeo
Send a message via MSN to kuroneko_sama Send a message via Yahoo to kuroneko_sama
i can relate, i got totaled with seemingly no damage at first glance from either side or at eye level higher than the hood, it was nearly impossible to tell there was even sundamage... unless you saw under the licence plate line
ironically and my visors were perfect
I Leave late and STILL manage to arrive early
Car #26..'97 SVX Silver (120k and climbing)
previous SVXi:
Car #24..'94 SVX Ebony 216k (sold)
car #18..'97 SVX LSI "Ebby" Pearl 175k (sold)
car #19..'97 SVX LSI Brilliant Red 103k (sold)
car #14..'92 SVX Claret LS-L Touring (sold)
car #13..'94 SVX Laguna Blue LS (sold)
Old 09-17-2006, 10:02 PM
momzsvx's Avatar
momzsvx momzsvx is offline
A mom with style ;-)
Send a message via Yahoo to momzsvx
Talking
Originally Posted by HighwayUFO
You guys make me laugh. I have found that velcro works wonders. Attach a small piece to visor and another to headliner. Viola, no more droopage.
Keith
I have that done to mine as well it does the trick...
MOMZSVX
92 LS-L parts
94-LSi My baby
95-(AWD) polo green T-Boned
Old 09-18-2006, 12:30 AM
David Cohen's Avatar
David Cohen David Cohen is offline
My car/My project: red '96 LSi
Arrow No More Droop -- Nice Tight Visors
After some trial and error I have gotten LokiDad's visor fix to work perfectly! Here are a few additions and modifications to the instructions:
Get the inserts
First, the part you're looking for is the Hillman 3/8" brass wood insert, the largest one in the assortment. I found it at Lowe's in the hardware section, in one of the specialty fastener drawers (containing "furniture nuts"). They were about $1.50 each. The little plastic baggie it comes in is marked:
HILLMAN
3/8-16
Wood Insert Nuts
Brass
UPC: 0 08236 70943 8
Get a tight fit, part 1
Once you get the visors off and opened up, you're probably going to discover, as I did, that the inserts are not yet a "deluxe fit"--they're too loose. The solution is easy: add a shim to tighten things up. Feel free to be creative; I just snipped a half-inch-long piece from a regular (3/16") width zip tie, and held it against the flat part of the post while I screwed the insert on.
Get a tight fit, part 2
Note that screwing it on is not going to be easy. Use a Vice-Grip. If you can turn the insert by hand (even with gloves on) then it won't be stiff enough to hold the visor up! Test it by seeing whether the insert is stiff enough to not turn by itself with the weight of the Vice-Grip clamped on to it and hanging sideways.
Order of Assembly
I found that I needed to properly position the insert on the post (to match the placement of the cutout) and then, with it already assembled, zip-tie it (just a couple of zip ties, to hold it while the epoxy cures) and epoxy it in place. (Note that the visor can't spin 360 degrees around the post, so you cannot screw the insert onto the post *after* you've glued the visor on. Don't epoxy the empty insert onto your visor!)
Other than the above refinements, LokiDad's instructions work great. Have fun fixing your visors!
Old 10-19-2007, 06:08 PM
Well, it worked for a year.
Sadly, this fix eventually stopped working--the visors became loose and droopy after a year--so I'm going to have to get replacement visors.
Instead of the instructions above, I would recommend trying this equally cheap and easy fix, which will probably work perfectly!
--David
Old 10-19-2007, 09:39 PM
kwren's Avatar
kwren kwren is offline
The ultimate fix!
I just bought new ones. Work great!!!
Old 10-20-2007, 01:44 AM
mbtoloczko's Avatar
sans SVX
--David
It does work ok for a while. Eventually, they will droop a little bit but not as bad as a busted visor.
Mychailo
Visit my locker
Old 10-20-2007, 02:16 AM
I'm afraid to touch mine after reading all this. thanks for the great info in advance. (good pics too)
blk 92' LSL w/ average mods
