Old 07-10-2004, 06:04 PM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Darned ball joint...
Okay, need a little help here guys... I'm working on a front wheel bearing replacement at the moment and got a little problem; I'll be damned if I can get the lower ball joint freed up. Anyone any pointers or advice on how to do it??
I'd detach it from the A-Arm but unfortunately I can only free up 2 of the three nuts... the third one appears to be slightly bent behind the hole so I can't get any tools up in there to free that one.
Anyone offer any pearls of wisdom on this one?
Old 07-13-2004, 03:06 PM
Wow, it's been too long since I changed my balljoint. Which bolt are you having trouble with?
Reference link
I don't remember having to remove that many bolts though. Heat and/or penetrating fluid can be your friend.
