Old 07-01-2004, 10:06 PM
LEOinFL
Stereo door falls down when opened
The stereo door doesn't glide down...it falls down. I also have to push on the bottom of it slightly when I depress the button to get it to open. Any way to fix the door so it glides down without replacing the whole thing?
TIA
LEOInFL
Old 07-01-2004, 10:20 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Hmmm. Sounds like it just isn't positioned properly. I would try repositioning it.
Take off black plastic shroud on door. It is only clipped on.
Remove screw on black frame panel (goes aroud head unit) and take out frame
There are two screws that hold the entire assembly in place. Loosen them and try to move the assembly around. Find a position that allows for smooth operation of the door.
Hope this helps.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 07-01-2004, 10:22 PM
LEOinFL
Thanks...I'm try it on Monday...gotta work all weekend.
LEOinFL
Old 07-01-2004, 10:37 PM
michael's Avatar
michael michael is offline
What Potholes ???
It could also be the spring that is supposed to push the door down. Mine popped out of place causing the same symptoms. If you pull the Assy. out of the dash just a few inches you will see it on the lower right side.
Wanted: Steering Wheel
