Old 03-08-2004, 09:30 AM
CDG's Avatar
CDG CDG is offline
No front plate on My SVX
Send a message via MSN to CDG
Yes, that would a dizzle of a shizzle.
The trany currently has the Level10 ValveBody. It would be nice to save it, if possible.
Chris G
92 Pearlie, sold @ ~209k miles. Now owned by Tim.
Current Ride, 1985 Honda Aero 80, stock 3024 klms
Old 03-08-2004, 09:33 AM
CDG's Avatar
CDG CDG is offline
I have been toying around with the idea of rebuilding my old trany that came with the car, it drove the car alright, but was very slow to engage in D and R. This may be a good candidate for a How-To on a rebuild. But I'm not sure I'm up for the task
I will need to think about this one.
Chris G
Old 03-08-2004, 11:00 AM
CDG's Avatar
CDG CDG is offline
Re: Sorry about your tranny......
Originally posted by Strictly Subaru
HI Chris;
Sorry to hear about your tranny troubles. I ended up working all day yesterday, and even 1/2 of today. So much for me getting my weekend off.... Anyway, I got your message about you looking for tires, unfortunatly I don't have any aftermarket, but I do have several sets of stock ones. I also have a couple of trannies for you, should you decide to keep using an auto. Send me an email with your phone number and I can call you if you'd like...
Hey Dan, you PM box is full
Chris G
Old 03-08-2004, 12:58 PM
WestCoastSVX's Avatar
WestCoastSVX WestCoastSVX is offline
Was MacGyver
I'm just catching up on all this, so sorry to hear that Chris!
You are now officially Northwest SVX meet casualty #2 and will go down in the memorials.
Troy
1992 SVX LSL "Serenity" 250,000 miles!
I don't care, I'm still free, You can't take the sky from me...
Old 03-08-2004, 02:24 PM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
I'm not so sure that would cuase failure, my last SVX had the tranny filter hooked up backwards for over 30k miles before i noticed it. check something else.....
phil
~Phil
Old 03-08-2004, 03:35 PM
phil
That depends on the amount of bits that it is catching. The right way around has a large surface area of filter to handel the crap. Backwards has only a small surface area that will fill quickly if there is enought crap.
Old 03-08-2004, 05:00 PM
CDG's Avatar
CDG CDG is offline
The inlet goes to the outside surface of the filter media, then flows back thru the center portion, this filter is the same design as a standard oil filter and they do work backwards.
But then theres the RAD cooling loop that the 94 and ups have, I can't see any reason why this would not work both ways, but thats the only thing left.
Chris G
Old 03-10-2004, 01:02 AM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
But I thought we (well, you and Earl, not me) figured the route out, and it seemed okay for a bit.
Old 03-10-2004, 08:21 AM
Strictly Subaru
Hi Chris...
Thanks for the heads up, I've just cleaned up my mailbox, it can now recieve pm's..... I will be home late tonite, if you'd like, pm your phone number and I can call you when I get in (around 10:00 pm'ish???) if that's not too late. If it is, I can call you Sat. morning. I'm still working out of town... Thanks.
Old 03-12-2004, 04:23 PM
CDG's Avatar
CDG CDG is offline
Thanks Dan,
So I grabbed a trany from Dan, and guess what, on my way home in my Legend, my Legend trany went very bad, making familiar grinding noises, its a 5 speed, a little smoke from the clutch, but made it back to work.
Boy am I having fun.
Please note an update to my post in the Wanted or For Sale section.
New Trany from Dan planned to be installed by my now experienced and rather reluctant mechanic next thursday. He was willing to do it again, but he said this is not a good pattern for me
Still have not investigated true cause of failure, stay tuned.
p.s. any of you who I helped, please check your cars again, I'm cursed
Chris G
Old 03-18-2004, 08:40 PM
CDG's Avatar
CDG CDG is offline
My mechanic has installed the used trany.
He has made the following recommendations with regards to the flow of the trany fluid and what goes where.
Fluid should come out of trany and go to filter,
from filter, go to external cooler,
from external cooler to Rad cooler.
Justification is that Auto tranys don't like it too hot or too cold, so this flow plan is the best for all auto trany's.
As far as where I went wrong, he'll be letting me know tomorrow. He will be flushing old components, cooler, rad, and filter.
Then install new external filter, and plumb it as described above.
He will then flush the system completely, including the new trany.
He will then drop the trany pan, replace the internal filter, and the external filter, and flush-fill the system with fresh trany fluid.
He will be testing the flow.
He wanted me to confirm which line on the trany is the outbound and which is the return. He will also be chacking with a trany guy, wants to make sure there is no confusion as he suspects that would be a good reason for all my troubles.
On the trany, is the line at the front of the trany the in or the out?
Chris G
Old 03-18-2004, 09:57 PM
Alycone's Avatar
I'll look forward to seeing the new tranny setup at the next meet.
Old 03-18-2004, 11:21 PM
CDG's Avatar
CDG CDG is offline
Ya, me too
Chris G
Old 03-21-2004, 02:57 PM
Oil flow.
The hot oil flows out the front of the case. The cool lube oil goes into he case at the rear.
Old 03-22-2004, 03:19 AM
Alycone's Avatar
