Old 12-03-2003, 01:19 PM
ChrisR
225/60/16 Tires too big?
I found some really nice used tires for $150 bucks. BUT, they are 225/60's. Is this too tall for the a stock svx?
Thanks
Old 12-03-2003, 01:35 PM
Mr. Pockets's Avatar
Moderator
They're going to be a couple centimeters taller. My guess is that they might fit, but at the least your speedometer is going to be way off.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 12-03-2003, 02:29 PM
immortal_suby's Avatar
Thread Killah
I had either 225/55 or 225/60 on my svx when I bought it. Whichever they were, they rubbed during hard cornering and even worse when I had passengers in back.
Locker Link
2015 BRZ Limited 6MT
Old 12-03-2003, 04:26 PM
nordique14's Avatar
Who watches the watchmen?
tire size calculator
I know this doesn't help you figure out if the tires will fit on your car, but it will help you figure how far off your speedometer will be if you switch from stock tire size. Much easier than calculating it yourself.
http://www.miata.net/garage/tirecalc.html
Old 12-03-2003, 04:29 PM
With 225/60-16's you are approximately 7% faster than the speedometer indicates.
Stock tire height - 24.86"
225/60-16 height - 26.63"
Green1995SVX
I hate it when I see people trying to save a couple bucks by doing something like this. If you cant afford a set of tires of the correct size for your SVX, then getting it was probably a bad idea.
Mike
Old 12-03-2003, 06:39 PM
JLittell
For safety reasons I would not recommend putting on different tires other than those that are required on stock wheels... I got to agree with Mike...Get some tires that are supposed to fit..
Old 12-03-2003, 09:40 PM
ChrisR
Wow, that's too bad, since I wanted to save a few bucks on some tires, I guess I will just have to roll the svx off a cliff because I can't afford it.
I'm just kidding with you, Mike.
But it is quite common to put on different tires on stock wheels. I have done it, in fact, on every car I have owned. Sometimes it is to save a few bucks, sometimes for better performance. I figured 60 series tires would be too big, but I thought I'd ask. By the way what is the stock size tires for the svx? 225/50/16? I guess I will just spend about 300 more dollars to get the "correct" size.
Thanks for the replies.
Old 12-04-2003, 03:54 AM
6evil9
hey nice site
seems like 225/45/R17 looks to be best for svx
considreing look/ weight/ perfomance/price/ being similar to standard issues
Old 12-05-2003, 12:02 PM
svxsubaru1's Avatar
how wide can you go on the stock rim, with out any rubbing, 245s maybe?
Old 12-05-2003, 12:28 PM
Green1995SVX
People have successfully used 245 45 16's on the stock svx wheel.
Mike
Old 12-05-2003, 03:18 PM
RSVX RSVX is offline
Network Design Administrator
Tirerack.com ?
Life is a game. Play to win.
Old 12-05-2003, 04:34 PM
The following tire sizes are very similar in terms of height:
205/55-16
225/50-16
245/45-16
Old 12-05-2003, 09:42 PM
ChrisR
Originally posted by RSVX
Tirerack.com ?
Cheapest I found on there was about $316+shipping +mounting when they come. I always thought tirerack to be a good, but never the best deal. My favorite is www.victoriatire.com . But $150 mounted I thought was a good deal. But bad size. too bad.
Old 12-06-2003, 10:21 AM
96svxer
I've run 225/50/16 225/55/16 and 225/60/16. I dont understand why it would be unsafe. Your speedo is going to be off slightly, but as long as you have the same speed rating on the tire it should be fine. Save the 300 and go buy me some christmas presents!
