Power Steering, how it works?
My power steering has been working well for the past week since I fooled around with the sensor near the power steering pump. What does this sensor do? No dash lights lit up when I un-plugged it. Mine is a 92 with speed sensitive steering. It has never seemed that speed "sensitive" though. How does the speed sensitive steering work? Does the pump vary it's pressure?
I would like to know why the binding in my steering simply went away. I do not belive it is a rack problem now. Racks don't usually just get better. Thanks!!!!!
Paul 1992 LSl (Black Mica) 1965 Mustang G.T. Fastback 1990 Mustang G.T. Convertible 1986 1/2 Nissan 4x4 2004 Vovlo XC70 (wife's) Wonderful Wife Wonderful Son 2 Cats Incredibly blessed! |
That is great the binding went away. It may have something to do with temperature. Have you changed the fluid?
The PS system workings? If I get time I'll look in the FSM. |
Thanks, Paul |
I also have a 92. How do you know whether it has speed-sensitive steering and also which type. I have seen references to a couple of different type of steering systems. Are there any descriptions on what is different or how each works.
Thanks |
my power steering has been cutting in and out.. it primarily cuts out when the car is still cold.. once i drive around a bit, things start to feel fine.. but i get a stiff wheel and a bunch of christmas tree lights when i try to turn the wheel right after starting it... i checked the belt and it's not slipping or anything
-adam |
Re: Power Steering, how it works?
The Last thing I did was add the additive, so I'm assuming that is what got it going, it might take a while to work in Either way I'm just glad it's working
Re: Re: Power Steering, how it works?
I am going to put that stuff in my stang and truck. Good stuff.
Here's what I know about how it works. You turn the steering wheel. That causes the front wheels to turn in the same direction as the steering wheel. I didn't say I knew alot.
I took the condensed Box-O-Tech course given at the RM Auto Mechanics & Clear Plastic Slip Cover School located in Maryland.
Larry III & The Beautiful Naviguesser '19 Tungsten Pearl Outback 3.6R Ltd...."AISHA" '08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU" '07 Gray Diamond Pearl Outback XT Ltd..."AH SO" '05 White Pearl & Silver BAJA Turbo..."AH HA" '97 Bordeaux Pearl SVX LSi..."SUBYDOO" '94 White Pearl SVX LSi..."PEARLY" '92 White Pearl SVX LSL w/touring pkg..."SVXY" '92 Teal SVX LSL w/touring pkg..."ALCYONE" '96 Polo Green LSi ... "MIDORI" '00 Black Dodge VIPER RT-10... "VINNIE" Engineers do it with precision. English teachers are novel lovers. Home: larrysingeriii@comcast.net SVX FEVER, CATCH IT AT A MEET NEAR YOU !! |
That sounds like the same kind of trining we get, or should I say "git" down here in NC. |
Hey guys. Just for the record, what is the name the additive goes by? Is it a Lucas power steering additive? I have used a Lucas a/t additive. I am not sure about the results. It doesn't help the 2-3 flair.
The bottle is at home, but I think it's the only "Lucus" brand that is for power steering.
Yeah, Lucas Power Steering aditive. I think it also says something about "stop leak" as well. It's a white bottle with a funny tip, almot like a squeeze bottle.
Paul |
