Snap- no pwr to the wheels :( diff?
So driving my 94 L fwd.
was getting on the fwy this morning had gottin up to about 60mph and heard one loud snap/bang. Then it rev'ed up. Pulled over and the engine was still running but wouldn't move in any gears. ... Maybe the diff snaped? I heard no grinding sound tho .... But the car has a ticking sound from the trans area before it stopped and still does after tho so idk if it has something to do with it. Any ideas? It may be time for awd 5speed conversion
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Re: Snap- no pwr to the wheels :( diff?
maybe the flex plate snapped?
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
^ Sounds like a flex plate to me too.
Replacing the flex plate requires pulling either the trans or the motor (or both). Use a phase 2 flex plate, as they are stronger. (Searching should yield the part number).
HERE IS THE UPDATED FLEXPLATE AND PART NUMBER 12332AA071 The old style plates were 2.05mm thick The new style plates are 3.25mm thick .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-13-2013 at 02:39 PM. |
K.I.S.S. check both axles first as if one snaps internally or externally car go nowhere.
The "ticking sound from the trans area" sounds like broken flex plate, but maybe a snapped axle would make a similar noise?
Yeah i am gonna check the axles first. If i put the front end on jacks and put it in gear will a wheel spin if one axle is broken?
.. I popped open the TC bolt access hole i saw the flex plate spinning.. and a few weeks ago i checked all the TC bolts so i know its not them.
may move in the air but may not,
Thread Tools | |
Display Modes | |
