Horn went off while I was driving
I did a search and some people had issues with the alarm system. But it sounded like the horned beeped a few times for them. For me, it started honking and stayed on steady until I pulled over and shut off the car. When I restarted it, the horn was off and stayed off. I didn't notice what other lights or indicators might have been lit up.
Any suggestions as to what I should check?
Re: Horn went off while I was driving
It would be possible to hold the steering wheel incorrectly and the horn button would be depressed while driving down the road. When I do that, it usually startles me and I jump and then re-grip the steering wheel differently. Seriously, I would start by looking up the horn circuit on the wiring diagram and see what I need to check. Hopefully it won't happen again... was just a fluke! Good luck with it Tony. Take care, Keith |
No other suggestions?
I second checking the horn relay.
I checked the service manual and it isn't obvious where the relay is. It looks like the damn rear speakers. It looks like I will have to pull apart the entire car to get to it!
