Old 05-23-2009, 08:17 AM
svxash's Avatar
svxash svxash is offline
Who's using speed bleeders?
So my front calipers need rebuilding so I'm going to do all 4. It was mentioned in another post to use speed bleeders. Who's using them and where's the best place to get them?
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 05-23-2009, 08:37 AM
Re: Who's using speed bleeders?
I used them on a CJ5 and found them to be rather useless. I thought they would be a great addition, but after wards i concluded that they were a waste of money. Too bad as I thought they were a great idea. This is my sole 'hands-on' with them, so others may have differing experiences.
Why not just gravity bleed? This has gone good for me on at least a bill of cars in about every make.
blk 92' LSL w/ average mods
Old 05-23-2009, 09:06 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
I have them on my SVX. I think they are great. They turn the task of bleeding brakes into a 10 minute one-man job. At the race track, that is indispensable. You just start at the farthest caliper, open it up, stick on the hose, pump the brake pedal a couple of times, pull off the hose, tighten it back up again and go to the next caliper. You can do it almost as fast as it takes me to write it. Note that you don't have to keep the brake pedal down after the last pump to avoid drawing new air into the system, which is why normally brake bleeding is a 2 man job. The one-way valve keeps air from entering the open valve.
Old 05-23-2009, 10:29 AM
I have them on one of my cars and they are great. +1 with the post above. The only down side I see is the price. If I remember right, they are about $35 a set.
Old 05-23-2009, 10:37 AM
SuberNatural SuberNatural is offline
+1 on that I have russel speed bleeders and they work awesome
1992 Liquid Silver/Black LSL
LeveL10 Stage 3 Trans and associated stuff
Old 05-23-2009, 10:55 AM
Here is the link to the speed bleeders. The price has gone down some. Now about $20 per 4 + shipping.
Old 05-23-2009, 11:00 AM
That's right where I got mine. Helps if you have other stuff to buy to offset the "handling" charge lol
Old 05-23-2009, 11:08 AM
Yes, like a dozen or so more sets of them.
Old 05-23-2009, 11:12 AM
LOL ya, they have some good prices on stuff but if you do small orders you get whacked.
Old 07-09-2009, 07:24 PM
svxash's Avatar
So I bought the ones from Summit and installed one in the rear. I bled the brakes until the new fluid came out. I then pulled off the other rear wheel and installed the bleeder. I got out to check the hose to see if the old fluid had been flushed and the dust cap was blown off and there was brake fluid all over the wheel I had already done!!! I checked the bleeder to see if it was tight and it was. Well come to find out the bleeders were packaged wrong from the factory. The part numbers were ok but they were about 3mm shorter than what the Edelbrock rep said they should be and weren't seating. Anyway they are sending me new ones. I'm glad I noticed the fluid and didn't go for a drive.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Display Modes
