Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Audio/Video/Nav/Security
Old 04-04-2008, 03:43 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
Capacitor
Anyone with experience know how I could figure out what kind of capacitor I need for my stereo system? Like how many farads or whatever?
Old 04-04-2008, 04:02 PM
Paulrio74's Avatar
Paulrio74 Paulrio74 is offline
yes, but more information is needed. For example, if the lights are dimming, is it because the stereo pulls to much peak amperage, but typically leaves enough left for the car, or does it always pull to much, leaving you stranded when the alt dies or battery isn't able to charge. How many watts? How many amps do the fuses add up to? How efficient is the amp/amps? What are the symptoms causing you to suspect a cap is required? Sometimes a cap does nothing but use the money you should have spent on an alternator, sometimes it helps. Are the main power and ground wires upgraded/maintained at least? What distances are between the amp and alternator? What gauge cable is it using? Is there a meter handy to measure actual draws on the line? It's a hobby of mine...as a general rule, I've seen 1-2 farads per 1000 watts output suggested. Again, that may be a complete waste of money in your situation, and lower end caps (some) can be shown to put a heavier load on the system while providing no benefit at all.
Old 04-04-2008, 06:45 PM
Trevor's Avatar
Trevor Trevor is offline
A capacitor close to the stereo system acts as a stored source of energy, which will fill in only very short term high load peaks, which drop the voltage at peak volume levels, as a result of line resistance and or inadequate supply capacity. There is no way of estimating your requirements, other than by cut and trial. You can take it that the the more capacity i.e. measured in farads the better.
Trevor, New Zealand.
Old 04-04-2008, 08:02 PM
lilbrudder lilbrudder is offline
i can make it on my oooowwwnn!
i use 1f for my 1200 watt system and optima red top, works beautifully.
Old 04-05-2008, 12:06 AM
IceBlade's Avatar
Hm thanks for the responses. My speakers only put out 560 watts and my sub does 300 but I eventually want to get another. Well those are the nominal outputs anyways. So I think I'm probably fine. The only reason I want one is because sometimes I'll have my car off but stereo on and I don't want it draining my battery.
Old 04-05-2008, 03:57 AM
Trevor's Avatar
A loud speakers can not put out watts i.e. electrical energy.
A capacitor can in no way reduce the load on the battery.
Old 04-05-2008, 05:46 AM
SomethingElse's Avatar
word words wording
sounds like what you need is a power inverter. This way you can plug in your retractable extension cord to taco bell (or burger king) when your loitering in the parking lot. this will keep your battery from expiring when your boomin your bass for all of your peeps
Trevor nice STI badge!
Eric
Old 04-05-2008, 06:59 AM
AFBeefcake's Avatar
Subaru Swapper
A Cap will not stop your battery from draining.
2005 Legacy GT
My WRX's Cardomain Page
Old 04-05-2008, 08:26 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Run your audio stuff to an extra battery in the trunk
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-05-2008, 09:20 AM
IceBlade's Avatar
Hm I guess I'll have to make due with what I have. Thanks, guys.
Old 04-05-2008, 07:25 PM
Trevor's Avatar
[QUOTE=
Trevor nice STI badge![/QUOTE]
Just how did it become included. Not by my doing.
Old 04-06-2008, 12:30 AM
Paulrio74's Avatar
I do remember seeing a cheap little device that would set off a circuit breaker if the voltage dropped too much. I think it was for cars at the airport and such, around 30 bucks. You could listen until the power died, then pop the hood, flip the breaker and drive away. It would still likely delete the presets and such though. I'm not sure they are even offered anymore.
Old 04-06-2008, 09:40 AM
IceBlade's Avatar
Hmm thanks, maybe I'll check that out.
Display Modes
