Wtb: Rad Fan
Fixed my old one and now it's died.
WGJ |
Which side? I think I have a good driverside.
I actually have 2 identical fans on mine. I blame the previous owner(s).
But have they given you any problems? PS: Why are they different? Most of the times they run together...
I believe one has 5 blades while the other has 6. I've never replaced mine but the holes for the bolts keep needing larger washers to hold them in place.
I have two identical fans on mine. I took the wrong one out of my mom's parts car. It works fine, but doesn't mount as easily. I haven't had a problem, but some day I'll swap it for the right one.
*better not happen*
Thanks Alot I Wuz Gonna Ask You That Question...
[QUOTE=SSSVX]Is that more blades is Always better? Say, if one of the fans stopped working and I upgrade to a better and more powerful fan...would that cause any problem?
WGJ |
I would say the more blades of the same size the better but I'm sure there's an optimal amount for airflow vs noise.
