Old 01-04-2006, 12:14 PM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
AWD Solinoid and Error Codes
Hello,
My babys in the shop. Aparently (well very obviously, thanks snow) the AWD is not working. During it's prior visit the Subaru Dealer said that solinoid C should be replaced. They did good work last time, and really seemed to care about the car. Now, I'm not sure if it's the same mechanic, but he's looking at it and he says that the've done some test and no error codes are showing up and the AWD seems fine.
Do you ever not get error codes from a bad solinoid C? Could it be my clutch plates instead? The AWD is just flat out not engaging from what I can tell. No shudder, not binding, nothing.
Old 01-04-2006, 02:42 PM
oab_au oab_au is offline
Originally Posted by greggbzz
Hello,
Hi Greg, yes the clutch plates can be worn out, or the transfer valve could be stuck, so that when the C solenoid turns it on, the valve does not move and the clutch won't operate. There won't be a code posted as the C solenoid is working OK.
The fix is to remove the rear of the box, and replace the C solenoid/transfer valve assemble, the clutch plates can be replaced at the same time. About $300.
One Arm Bloke.
Tell it like it is!
Old 01-04-2006, 03:21 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Send a message via AIM to Ricochet Send a message via MSN to Ricochet Send a message via Yahoo to Ricochet
Anybody got pictures of this stuff and where exactly they are?
Brian
Old 01-04-2006, 03:44 PM
Earthworm's Avatar
Meow!
Check subaruparts.com. Solenoid is in the "Extension" section and clutch is in "Transfer" section. (Both under transmission)
