Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 12-05-2005, 07:04 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
stage 2V5 questions
I searched and It doesnt say on the website but does the stage 2v5 raise the RPM limit to 7400 like the 1v5 does?
[SIGPIC][/SIGPIC]
STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit.
Old 12-05-2005, 08:45 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
I believe that all of ECUTune's SVX chips have this feature - I was under the impression that the rpm limit was only raised to 7000 rpms....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-05-2005, 09:03 AM
jman050's Avatar
Its a Classic!
I had thought it was 7000 to but when i checked the ECUtune website it said 7400 for the old stage one so im not sure.
[SIGPIC][/SIGPIC]
Old 12-05-2005, 10:04 AM
SVXRide's Avatar
You know, I think you're right...it really only applies to the 5 or 6 spd folks, as the 4HEAT kicks you out at 6500..
-Bill
Old 12-05-2005, 01:01 PM
Earthworm's Avatar
Meow!
Mine would cut out at an indicated 7200RPM at best due to the MAF issue. I still only have the Stage 1V3.
Old 12-05-2005, 02:38 PM
jman050's Avatar
Its a Classic!
is there anyone that can verify that the 2v5 with MAF allows the rev limit to be raised?
[SIGPIC][/SIGPIC]
Old 12-05-2005, 03:02 PM
Earthworm's Avatar
Meow!
I wish I could. I can't justify the expense at the moment.
Old 12-05-2005, 03:15 PM
7400 rpm is right... I tend to run it to 7200 or so in 1st gear when I dragged the car... unless you upgrade other parts on the car running at that high rpm is mostly useless
Old 12-05-2005, 04:34 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
ditto....i reached 6950rpms on the dyno so its been street and dyno varified..
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
