Help me decide if I should buy that Aluminum Radiator
I have a 1992 "unmodified" Teal SVX with no filter, cooler, or anything else on the transmission. I had to add a pint of ATF last month & I'm sure it's the original fluid. It's only got 37,000 miles. I also smell antifreeze in my garage on a warm day, after a long ride. The radiator is either leaking up near the cap, or boiling there a bit, because the foam rubber near the top is wet with green fluid. It's been recently flushed and filled (last winter), but it's the original plastic multi-shaded radiator. I asked the Suby dealer to check it out & he just dumped in a can of stop leak.
I've been debating whether or not the get that new aluminum radiator for this car. The fact that it has no tranny cooler could prompt me to do this, rather than spend the money for an add-on cooler. I also have a red '94 with an "all black" plastic radiator (original, as far as I know) with 141,000 miles on it, so I figured I could uses the teally's radiator as a spare if the red one's craps out on me some day. Sound like a good plan? Does it REALLY only take an hour or two to change the radiator on these beasts? I'm not a mechanic by any means, but I can change a thermostat, hoses, etc. and am somewhat mechanically inclined. Cap
Cappy '94 LSi Barcelona Red 158,000 miles '92 LS-L Dark Teal 47,000 miles '95 Olds Acheiva 104,000 miles '85 Audi 4000 135,000 miles '87 Supra 129,000 miles - 2nd JDM engine |
Yes - it is a good radiator. I'm very happy with mine. It shouldn't even take an hour to change it out the first time. Do somehting soon though - it sounds like you radiator is on it's last legs.
Make sure you thoroughly flush the system before putting in a new radiator. You have to get that stop leak gunk out of there.
I also recommend flushing that stuff out of the system. Is your rad already cracked? There's usually an approx 5" crack going along the top tank of the radiator.
Look closely at the top of your radiator and you'll probably see a hairline crack along the bulge in front of the filler neck that's allowing coolant to escape under pressure.
The original radiators had a screen in the transmission cooler that apparently becomes blocked easily if there's no filter upstream; all the more reason to get the old radiator out of there right away. dcb |
Best Fix: aluminum radiator (read good things about it, does anybody have pics of it, both alone and installed?)
Good Fix: swap radiators with your other SVX as soon as you can. Home Depot Engineering Fix: drain radiator fluid. Find the top hairline crack and lightly grind the inside of the crack with a dremel (make the crack like a rounded canal). Sand the entire surface with 400 grit sandpaper, clean all dust with a cloth dampened with a bit of acetone. Mix some JB-Weld as accurately as possible and apply inside of the crack canal and all around it. Let it dry for 48 hours if possible. The last fix is ghetto but saved me on two similar occasions... I eventually proceeded to get new radiators in those occasions, but the fix was holding up strong. Remember (this applies mostly to performance upgrades but it's a good guideline nonetheless - don't ask me how I know): Reliable + Fast = NOT Cheap Reliable + Cheap = NOT Fast Fast + Cheap = NOT Reliable Good luck, Walter
1995 SVX Green - now 5spd! ..::|SOLD|::.. 1991 Talon TSi AWD (~400 whp pump gas) 1993 Civic CX Hatch (daily driver) 1999 Ducati 748S (built 996 engine) |
Less than an hour to install for me, probably an hour roughly.
-- Chris Founder/Administrator SVX World Network ECU Tune (stage 1), PWR (prototype aluminum radiator) Amateur Radio - General Class - K7SVX #1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed) #2 92 Teal LSl 125k (Retired, car rescued from a field of weeds) 2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver) 2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler) 1985 Honda VF500 Interceptor (fair weather fun commuter) Going on 11 years of NHRA bracket racing NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com) 2000 1st Place Club Challenge Series 2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway) 2003 4th Place Season Track Champion, Import Racing (Firebird Raceway) 2003 1st Place NW Regional Import Shootout (July 5th) 2004 1st Place Club Challenge #1 (Firebird Raceway) 2004 1st Place NHRA "King of the Track" race 2004 NHRA Gold Cup 2nd place season win 2004 Import/Sport Compact 3rd place season win 2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC) 2007 1st Place Import Survival #3 2007 1st Place Track Champion Import Summer Jam (Wild Street Class) 2007 1st Place Import Survival #5 2008 Club season 1st place win, Club Champion 2008 2nd Place Season Import Final. 2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or) 2009 2nd Place Import Summer Jam (Wild Street Class) 2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2 |
Thanks for the advice. I probably WILL get the aluminum radiator as soon as they restock them. I looked again yesterday & could not see any crack along the top of the old one, but saw a single drop of fluid sitting on top, next to the cap. Heck, maybe it IS a bit of leakage. At any rate I can save the old radiator and use it as a spare if the one in my '94 red SVX (with 141,500 miles on it) ever fails. That one's already got a tranny cooler, and radiator bypass on it. Thanks again,
Cap
Maybe your cap is no good. Specifically the rubber gasket in it.
Try looking for a leak when the car is at normal operating temperature. The heat will expand the plastic top tank of the radiator.
Thanks for the suggestions. I never get a chance to look at this radiator when it's hot, 'cause my wife & I don't drive it much - it's only got 37,000 miles on it. But next chance I get that's what I'll do. And it would be great if the only problem was the rubber cap seal. But I'm still going to get the aluminum radiator...it's just TOO COOL.
Cap
:: Ooops... ::
Haha... guess what Capuano?
My radiator just failed yesterday! Go figure... I finally get my car back from one failure and something else happens... Yesterday evening I parked in my driveway and as soon as I stepped out of the car I smelled the unmistakeable coolant fluid... hmmm not good I thought to myself. Got back to the car with a flashlight and popped the hood. A nice green line with bubbles was grinning at me from the top of the radiator. Oh well, I guess that leaving the radiator empty sitting this past month or so while I was doing my timing belt further weakened the top of the radiator. Now I will have to use my JB Weld trick and cross my fingers for it to hold up. What about you, how did you solve your problem? Regards, Walter
I coughed up the $450 for the Aluminum radiator. Sorry to hear about your dillemma, Walter, but the JB Weld option sounds like a very possible fix. If it weren't for the fact that I also need a tranny cooler on this car, it's the option I would go for. Good Luck!
Cap
Regards, Walter PS= take pics of that beauty and post them when you get it!
what's up cappy? haven'theard from you lately. if you want any help with the radiator install don't be affraid to call. i can make time for my fellow svx'ers. let me know how it looks when you get it. i'd like to get one here sometime but i'll probally end up just buying a tranny cooler for 50 bucks since my cooling system looks to be quite healthy.(knock on wood) let me know buddy, Jason |
