Old 02-08-2004, 12:31 PM
zavikan zavikan is offline
Send a message via AIM to zavikan
DIFFERENT seatbelt problem
OK! solved at least one problem with the seatbelt. a connection I was unable to see last time in the drivers door. then I manually brought back the seatbelt, and it worked for half a day. then it went to the rectracted posistion, and stayed there. I already checked all the connections to the motor itself, and it can't possibly be those. any other ideas?
Old 02-16-2004, 11:18 AM
96svxer
seatbelt help
The above link should help you. Dose your seatbelt fire when the car is running? Have you checked your seatbelt error codes? Have you used a voltmeter to check to make sure your forward, and retract limit switches are indeed working correctly? Your problem was very vague. Please explain more
