Old 12-17-2003, 01:54 AM
James Scott James Scott is offline
The Molinator
Question Vapor from engine . . . . .
Recently I've been getting an odor and visible vapor upon startup sometimes. When I pop the hood I see vapor rising up and backward from under the throttle body area (or intake tube) at the rear of the engine. Goes away after a minute or two (abruptly).
Any ideas? THANKS FOR YOUR THOUGHTS!
Jim
Old 12-17-2003, 02:47 AM
Reaper450128's Avatar
Reaper450128 Reaper450128 is offline
Send a message via AIM to Reaper450128
Is the same stuff coming out of your tailpipes? Mine does this too right now due to the fact that I have an exhaust leak just before the third cat, in my case its just water vapor in the exhaust. After a minute or two the vapor stops coming from the leak point and only comes out of the tailpipes, not sure exactly why. A simple test to see what the vapor is is to watch it as it drifts off, if it dissipates within a fairly short distance, its water vapor which is normal on a cold day, otherwise its smoke. You mentioned an odor, what does it smell like?
My two loves:
SVX: 1992 Black LS-L, SS Brake Lines, Slotted/Drilled Front Rotors, Level10 Stage 3 Trans, 4.44s, Phantom Grip LSD
PC: AMD Phenom 9950BE@3.0GHz, 4GB G.Skill DDR2, Asus M3A78-T, Radeon HD3850 512MB x2
Old 12-17-2003, 01:32 PM
Mr. Pockets's Avatar
Moderator
Re: Vapor from engine . . . . .
Maybe a small coolant pipe is leaking. That's my best guess. There are coolant hoses running into and out of the throttle body.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
