Old 09-12-2011, 04:51 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Time for me to move on...SVX in Columbus, Ohio for sale
I've been thinking about selling more and more this past year after I've achieved many fixes and maintenance on this car. I've always enjoyed this car, but I want to start saving for a new vehicle in 1 or 2 years. I've taken care of this car as best as I could and have stayed on top of routine maintenance since I've owned it.
I believe I have a lot to offer the right person. Check out my picture link as well. I have a few extras as shown below. I refuse to part-out the car, it just wouldn't be right.
I hope someone can take care of the car even better than I could have.
If interested, PM me or email me at sweetengineer78@yahoo.com
Location of the SVX: United States, Ohio
Year: 1995
Model: Subaru SVX L
VIN: JF1CX3353SH100539
Manufacture date: 08/94
Paint Color:Emerald Pearl
Interior Color: Gray (leather)
Miles: 161K
Options: Auto climate control, dual air bags, power windows, power steering, 6 cylinder 3.3 liter, cruise control, rear spoiler, AWD, power door locks, ABS, 8-way power driver seat, CD player (see below), leather interior, air conditioning
AWD or FWD: AWD
Modifications: Drilled and slotted rotors installed including pads (7/08), Small car shift kit installed, Alpine Stereo CDA-9830, California Amp AP1040 1000W, (2) 6x9 Kicker KS693 Rear Speakers, (2) Pioneer 6-1/2 Door Speakers, Removed center exhaust resonator and welded straight pipe in place to eliminate resonator rattle, Quick Change for transmission installed (purchased from svxworldforums.com)
Major service: (9/11 – Mileage 161,000 (6) new spark plugs and (6) new ignition coils installed)
(7/11 – Mileage 106,700 Internal transmission filter replaced, new TPS sensor installed)
(6/11 – Mileage 160,350 New knock sensors, AACV, PCV connector, PCV solenoid, Iris valve (used), Intake and Plenum gaskets, intake manifold vacuum hoses installed, adjusted TPS sensor
(5/11 – Mileage 160,300 (4) new struts with Koni Inserts installed, (4) new strut mounts, 4-wheel alignment, (4) new tires installed
(4/11 – Mileage 160,000 New IACV, Oil Sensor, Coolant Temp Sensor, PCV valve installed)
(7/10 – Mileage 157, 126 New LR and RR brake calipers and hoses installed)
(5/10 – Mileage 156, 948 New rack and pinion assembly, new front right CV Half shaft, new rear brake pads, used brake proportioning valve installed)
(10/09 – Replaced all sway bar bushings with new ones)
(5/09 – Recharged air conditioning system, replaced high pressure power steering hose)
(12/06- Rebuilt starter installed)
(6/06 – mileage 130,898 – Replaced both lower control arms, replaced transmission gasket, transmission flush, replaced both rear sway bar links and bushings, replaced right front lower ball joint)
(9/05 mileage 124,836 – New timing belt, valve cover gaskets and bolt gaskets, water pump including seals, oil pump including seals, thermostat, cam and crankshaft seals, oil change)
(11/04 – mileage 119,088 - Initial inspection by Subaru after I purchased car – lube, oil, filter, 4 wheel alignment, replaced both oxygen sensors, tires rotated, heat shields re-tack welded)
Engine Condition: Good
Maintenance Records: I have only maintenance records since I had obtained the car in 2004 (major services listed above) I also perform normal tire rotations and oil/filter changes. I have all paperwork for minor services too.
Transmission condition: Good, smooth shifts, no known problems
Glass condition: Windshield new (08/2011), passenger side lower glass new (2008), driver’s side lower glass has a few scratches, all remaining glass in good condition (see pictures)
Type of tire and remaining tread: (4) Continental extreme contact (700) miles on them
Type of wheels: Standard SVX rims (4) silver (94-97 style) currently on the car
Interior condition: very clean, leather in good shape, passenger side sun visor droopy, leather above glove box getting loose
Body condition: Dings and scratches in various places, small rust spots on driver’s side door, front bumper cover has some cosmetic flaws with scratches, rear bumper cover has some scratches too, dent in rear passenger quarter panel (see pictures), small dent in front driver’s side fender
Known defects or problems: Cam seals leaking, possible drain pan gasket leak
Comments about the car: I love taking long trips in this car. It’s very comfortable and drives smooth. The interior heats up quick when cold outside. (see extras below)
Extras: I will include my (4) used tires/rims OEM with about .180” tread remaining , The used wheels consist of (2) gray rims and (2) silver rims from different model years ,(1) front bumper cover – used but in better condition, (1) complete set of used struts, (1) used front LH strut assembly, (1) ABS control module, (1) SRS computer , (1) used MAF sensor, (1) used TPS sensor, any other extra parts I have for the car, SVX technical disks, SVX owner’s manual, etc. Please see pictures, all is included *Trunk will be empty, just spare tire inside, I keep floorjack*
Asking price: $3200.00 Firm
Pictures: http://s805.photobucket.com/albums/y...78/1995%20SVX/
1995 Subaru Svx L / AWD
Old 09-12-2011, 06:32 PM
Sean486 Sean486 is online now
Re: Time for me to move on...SVX in Columbus, Ohio for sale
That's a very nice SVX and a ton of work has already been done on it. But, are you sure it is a "L"? I see AWD, Leather Seats and fake wood. Does it have a sunroof too?
Good Luck with the sale.
Old 09-12-2011, 07:00 PM
No sunroof, and the rest of the stuff is easy enough to swap into an L model.
It appears to have the vinyl dash pieces and arm rests which are the true dead giveaway of it being an L model.
Old 09-12-2011, 07:06 PM
msvx95's Avatar
It's just a phase
Ah I didn't know that about the armrests and L model.
No sunroof, Nate is correct.
It has fake wood trim and vinyl dash pieces ..armrests are vinyl too I believe.
Old 09-12-2011, 07:55 PM
Oh yeah, and I just noticed the the non leather steering wheel. What I like about the vinyl pieces and non leather wheel is that they wear much better than the fabric ones. Seats are a definite upgrade.
Old 09-16-2011, 05:10 AM
msvx95's Avatar
It's just a phase
Bump....
New price $3000.00
Old 08-31-2023, 11:44 PM
StimulusMistake's Avatar
StimulusMistake StimulusMistake is offline
I doubt you will ever see this but I own this car now (Since March 2021) and last week I finally began restoring the car. Someone was very, very bad to it and it is in rough shape. It's probably in part out & scrap condition but despite the logical choice I am doing my best to save the car. I've had to daily drive it the past year and a half and even briefly had to live in the car.
It runs like a tank and refuses to die. It's been beaten the **** out of so badly that I guarantee you that the only reason it isn't a bunch of coke cans by now is because of the amount you took care of the car.
(sorry if it pisses someone off by necroing this thread)
1995 Subaru SVX-L AWD, Emerald Green (225k)
Formerly owned by msvx95, ruined by someone else
1990 Isuzu Impulse, Spectra Red, (212k, patiently waiting for a drive train in a driveway in VA)
2004 Volvo S60 2.5T AWD, Ruby Red, (188k, in limbo)
Old 09-01-2023, 08:51 AM
That's pretty cool, 12 years later and it's still alive. Or as Robin Williams would sing..." oh, oh, oh, oh, barely alive, barely alive" (Bee Gees satire)
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
