Old 09-21-2016, 06:06 AM
arvirago arvirago is offline
SVX turns off while it's running
I would like to know if someone has ever had the same problem that I have with my SVX. It occurs from time to time and I have no idea what the cause may be. The fact is that my SVX turns off completely while it’s running. It happens at low speeds, and, as I see it, it’s very probable that it may always happen during a turn and without speeding up. The motor turns off suddenly and the car remains without any electricity, circulating under position D, as it would do under position N. The result is that, since there’s no electricity, the power steering does not work any more and it turns out quite dangerous to drive the car. I would appreciate any information about the matter or whether anyone has ever gone through this problem. Thanks a lot.
Old 09-21-2016, 09:00 AM
Re: SVX turns off while it's running
I think you'll find that there is electricity. The power steering is driven by a pump with a pulley. When the engine stops, the power steering pump stops spinning.
It sounds like your MAF sensor is failing, a common issue on an old SVX. Quite often it can be repaired by prying open the square cap on the MAF and re-soldering the connections.
There is a How To thread on this site.
Old 09-21-2016, 09:45 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Does the engine actually shut off? Do you have to turn the key to get it started again? Or is the only symptom that the power steering cuts out?
Old 09-22-2016, 01:29 AM
Cotton's Avatar
Cotton Cotton is offline
Some Random Weirdo
There are a lot of people with MAFs for sale. I can't imagine they would cost you too much. Ask on one of the FB pages.
94 SVX LSI- Rebuilt engine, 4.44 with trans cooler, Quick Change Shift Kit, SS exhaust with Magnaflow muffler, 08 STI Wheels, K&N Filter, and still adding.
Old 09-22-2016, 04:14 AM
Thank you very much for your responses. Hocrest, the engine does actually shut off and you have to turn the key to get the car started again.
What I usually do is to try stop at the side and re-start the car, when it´s possible. There has been some time that I´ve had to start the car on the N position since there was no chance to step aside.
I really appreciate all your support since I live in Spain and there are very few SVX in here, not to talk about the misinformation of the mechanichs, including those from the official mechanichal workshops.
Old 09-22-2016, 07:02 AM
It does sound like a MAF. Mine would do the same thing when it was going bad
Old 09-30-2016, 09:32 PM
elemgee elemgee is offline
My 94 did the exact same thing, more often right after I made a turn and gave the car some gas. It was the MAF. There is some info on this site on how to open up the MAF and do a little soldering to fix the problem. That's that i did and haven't had a problem since.
Old 10-29-2016, 02:18 PM
Chucksta Chucksta is offline
Ditto on the MAF sensor... Been there, done that. I had exactly the same symptoms. It was just like the key was pulled out of the ignition. At low speed, I'd have to hit neutral to re start.. at higher speed, especially if the torque converter was locked, it'd just pause for a second or two, and then the power would come back. It never threw a code for it either. I put in the spare from my donor car, and it took a few run cycles to smooth out, but it's been fine since..
