Ignition Bolts
Hey someone on the forum replaced the security bolts with Allen or hex head bolts and there was a thread on it but I can't seem to find it. Can anyone point me in the right direction???
Thanks, Jordan. |
Re: Ignition Bolts
The metric bolts are 8-1.25 metric bolts with about .75" grip length. That particular post can be found HERE. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-26-2009 at 10:13 PM. |
Re: Ignition Bolts
Mine have fallen out of both cars all by themselves and i just stuck std 12mm headed bolts in both times, you just need to undo the screws on the column suround and you right its much nicer to start when the ign is tight
cam |
Re: Ignition Bolts
Thanks a lot guys
I'm not sure if I know how to get my steering column surround off :P Just joking |
Re: Ignition Bolts
can you post that pic in focus?
Re: Ignition Bolts
Hey Cam, how are you going?
Here's a link to all my pics and some of my heater core process but before I post it, I just want you and everyone to know that this isn't a direct guide.. I will make a direct guide, there are screws, nuts and bolts which you shouldn't touch. http://s140.photobucket.com/albums/r23/TuRbZz/SVX/ |
