Old 05-17-2004, 06:00 PM
Originally posted by Sonar
UberRoo, -please clearify that cabling/switch you've found, and how do you know what it does?
Interesting
/Sonny
I think all models are fitted with this unit.
Its called a gear lever
Old 05-17-2004, 06:23 PM
Originally posted by deruvian
Looks like we may have to try Harvey's method. Have you checked it out Harvey?
No mate I am happy with the stock model I just like to help anyone that wants to try things, to keep them on the right track.
Yes there is no reasion why it won't. The temp sensor is a special resistor that reduces its resistance as it gets hotter.
At 20 degs C/68F it has a resistance of about 2.5Kohms
At 80 degs C/176F it goes down to about 330 ohms. Which brings the ATF light on ,and changes the shift points to move more ATF through the cooler.
Running a wire from one side of the sensor, to a switch, to a 220/330ohm resistor, then back to the other side of the sensor wire, will drop the resistance to a level low enought to do it. If the resistance is too low, the TCU may post a code.
Old 05-17-2004, 06:33 PM
My thoughts Harvey
So you don't see any sideeffects on this?
My first though was to put a potentiometer in parallell of the sensor, so I could adjust it to not trig the faultcode of a broken sensor, but maybe it's unnecessary.
/Sonny
Yes you could do that, to find the best resistance to use, as it is in parallel with the varying sensor resistance.
Can't see any side effects to it,other than the ATF light will be on, in this mode, so it can't signal a high ATF temp problem.
Old 05-17-2004, 07:19 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Re: Power Mode
Thanks alltrac! I never knew that... I do see that AT oil temp light at start up. Cool!
-Chike
Originally posted by alltrac
OBDll cars don't have a power mode light. They still go into power mode just no light to tell you. OBDll cars do have a AT oil temp light. You will see it on start up for a couple of seconds and then it goes out, unless you have a trouble code. If the fluid does get to hot while driving the TCU goes into power mode. Subaru should have called it shift mode, shift smart, shift logic or some other BS because it doesn't make powa.
2006 Steel Gray WRX TR (sold)
Old 05-17-2004, 07:39 PM
deruvian
I wonder if this would work on the FWD models, as they have no ATF temp warning light.
Does anyone know how the power mode switch works in the Euro model SVXen? Does anyone have a wiring diagram from one of these "switch-equipped" models? I suppose all you'd really need is a quality wiring diagram to tell you where to start.
Old 05-18-2004, 04:38 AM
Sonar's Avatar
Sonar Sonar is offline
I'm gonna do this when I'm back home this weekend
Maybe I rewire the original "ECON" function to some other switch (hidden), and wire the new "POWER" function to "ECON" switch, nice to have it handy in case of "emergency"
Maybe I relabel it to "DECFON MODE"
..and UberRoo, got me there ...didn't read and understand the post in full
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 05-18-2004, 04:44 AM
Sonar's Avatar
deruvian, the "Euro" model does not have the "Power" switch, that's why I'm trying to implement one
/Sonny
Old 05-18-2004, 04:46 AM
Sonar's Avatar
I think only the JDM model has one, maybe we ask Joe (svxistentialist) if he has a wiring diagram, he have a JDM (I think?)
/Sonny
Old 05-18-2004, 03:50 PM
deruvian
That's right... They have the Econ. switch instead. Woops.
Old 05-19-2004, 03:51 AM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
A couple of things you may consider, (or already have,) is that (1.) when the TCU is in power mode it tends to hunt for gears, and (2.) the "power mode" which is caused by hot ATF may not be the same power mode that is caused by rapid application of throttle.
In normal operation, there's a margin between how much throttle is needed to get a downshift and how little throttle is needed to get an upshift. This 'null zone' keeps the transmission from switching gears at the slightest change of throttle. In power mode, the 'null zone' becomes very narrow and almost undriveable.
The next time you're at freeway speeds, romp on it and get the TCU into power mode, then abruptly let off the gas for just a second - maybe a couple of times. Notice how quickly it changes gears? It's like an annoying hiccup. If you do this a few times, you'll find the transition point (where it shifts) on your throttle pedal. If you hold the pedal at that point and just wiggle your foot slightly, it'll jump back and forth between gears like crazy (as long as you're in power mode.)
You can do this at low speeds too, but it's a bit harder to do as the TCU goes back into normal mode rather quickly. Power mode works very well if you just want to accelerate, but the TCU gets very confused if you want it to do anything else.
I think you'll find it very undriveable. Don't get me wrong. Experiment with it. It'll probably be a pain to drive, but a lot of fun while you toy with it. If it works, you'll be a hero to many.
UberLocker
Old 05-19-2004, 07:55 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
No offense, but I have to disagree. I drive a JDM SVX (factory fitted with a power mode switch). It is not almost undriveable and it doesn't jump back and forth between gears.
I regularly drive with the power mode switch on because it makes the car feel a little more responsive - it tends to be in the right gear at the right time, rather than being one gear too high.
Phil.
Old 05-19-2004, 11:46 PM
UberRoo's Avatar
SVX Appeal
b3lha,
I would not disbelieve, but would be surprised if your Power Mode button causes the same performance that the automatically activated power mode causes in U.S. cars. I know that the power mode does cause some undesirable behavior in my car, but because the mode is used only in great moderation, it's of relatively little consequence.
How does your Power Mode button work? At what speeds does it downshift when coasting? How is it wired? It would be very interesting to know if the behavior of your manual activation is the same as our automatic activation. It would also be interesting to know where the wires go. Perhaps you share the exact same TCU, and the only thing missing from ours is the wiring and switch. That would be very cool.
Personally, I like driving the torque-monster. I love being able to climb steep hills in high gear with the torque converter locked up. ...but your right, it's not sporty, and I understand why the shift points would not suit your mood if you're feeling frisky.
UberLocker
Old 05-20-2004, 12:22 AM
paddlesnz's Avatar
paddlesnz paddlesnz is offline
Send a message via Yahoo to paddlesnz
JDM models
JDM models have the same 'automatic' activation of 'Power Mode' as US models. Plus 'manual' activation via the console switch.
paddlesnz
1993 Subaru Alcyone SVX
1980 Isuzu 117 Coupe Giugiaro Edition
1999 Mazda Astina
2006 Honda Legend
2006 Toyota Mark X Premium
2007 Toyota bB
2007 Mazda Roadster RS
2012 Peugeot 208 Allure
Old 05-20-2004, 07:42 AM
b3lha's Avatar
Phil & Belha
I think the non-US cars have a different TCU because of the VTD transmission (as opposed to the US clutch type). I've never traced the wires, and I don't have a diagram, but I assume the switch just grounds a pin of the TCU.
I find the downshift points difficult to determine, but at WOT, it seems to upshift at the 6500 redline: to 2nd at just over 40mph, 3rd at about 85 and 4th at about 115-120 (although I rarely go that fast).
Phil.
Old 05-20-2004, 08:45 AM
deruvian
Damn... Good point. I was just starting to get hopeful.
Does anyone on the boards have a JDM ECU or TCU wiring diagram?
