Old 05-22-2004, 02:43 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
Messed Things Up More
yeah, so i removed the valve body from the transmission, and fixed the shorted wire to the shift solenoid that was giving me trouble... now the car goes forward in reverse. i almost drove off of the front of my wheel ramps..
does anyone have any ideas what i did wrong?
it just doesn't make sense to me, the wiring is right now, the vavle body is back and bolted in correctly,
SV What?
Old 05-22-2004, 04:28 AM
NomadTW's Avatar
hmm now it won't go into gear at all
every gear just revs
SV What?
Old 05-22-2004, 02:28 PM
Green1995SVX
buMp
Old 05-22-2004, 02:42 PM
lee lee is offline
Did you disconnet all the solenoid wires? Then are you sure they went back on the right solenoids?
Old 05-23-2004, 05:53 PM
oab_au oab_au is offline
Reversing to hell.
I can't see any way you can get the low/reverse clutch to operate without the gear lever being in the reverse position. It is a vital part of the operation. Make sure the lever is operating the gear box, besides the inhibitor switch.
One Arm Bloke.
Tell it like it is!
Old 05-24-2004, 12:30 AM
gl1674 gl1674 is offline
The forward-reverse selection is not done by solenoids, it is done by a mechanically driven valve (that long stick in protruding from valve body). It is normally hooked to the gear selector.
Most likely you did not hook it up properly when you put the valve body back in. Although I'm not sure if it is possible to put valve body back in without properly connecting the valve - when I tried to do exactly that :-) something just diid not fit right.
Old 05-24-2004, 01:38 AM
NomadTW's Avatar
long stick protruding...
the one that tries to fall out when the valve body is not level?
yeah that went back in... but didnt' connect to anything, it just sat there
should it have connected to anything
none of the gears work, reverse or forward they all just rev
it was suggested to me to overfill the transmission and just let it sit with the engine at idle for abotu 15 minutes to give it a better chance of flushing out any air bubbles in the hydraulics of the transmission
is this good advice?
SV What?
Old 05-24-2004, 01:57 AM
NomadTW's Avatar
yeah... that's it
i deffinatly did not connect that to anything
stupid service manual didn't say anythign about it, so i just pushed it in... and put the valve body back...
well thanks you solved the problem
now i just need another day off to fix the car right
the brain trust here comes through again
it's all a learning experience for me.. i enjoy learning so it's a good thing i have an svx
SV What?
