Trunk is stuck closed
i can not open my trunk anymore i tried to use the key it does not work should it be the same as the ignition
yes your ignition key should work....maybe the "cancel/open" switch got stuck...try pushing down on the trunk more, then use the key again....turn the key to the right as if you were locking it....it should release....
If you get it open spray the hinge with silicon spray or something...also I think the lock should be set to "cancel" |
Is your ignition key grey? If so, you have the Valet Key, and it will NOT open the trunk or the glove box.
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
key does not even turn and the safety switch is off well it is set to open by the little latch thing
ignition keys are black
OK, does your ignition key unlock your doors? I suppose it possible the ignition system has been replaced, and you have a different key...
Do you have any other/extra keys?
just the stock subaru keys let me check the doors real quick
Questions
Can you get into the trunk through the back seat or is that switch also in the lock position? Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
no that is how i seen the switch i crawled into the trunk and no the key never worked how would i tell if the ingnition has been changed
anybody gat a pic of a stock key
