underhood wiring diagram?
hi folks!
i've tried searching the site to no avail...i need to see a copy of the underhood wiring diagram... i have a moderately thick black wire with a red stripe at the rear-centre of the engine directly above the trans/engine mating surface... it is broken and i cant find where it goes! (it appears to have had a "ring end" connector that has broken off ) i have just removed all the a/c stuff underhood (likely how the wire was broken ) i also found a failed harmonic balancer, which i replaced with a stock unit. upon reassembly of everything, the car wont start...grrrrrrrrrrrrr!!!!!!!!!!!!! there is power to the starter solenoid and when i cross the poles, the starter spins, but the solenoid wont engage the gear to the engine... this broken wire reaches the starter easily enough...but i dont see the remnants of a broken ring-end connector on the starter.... when i turn the key, the starter doesnt even spin...NOTHING happens at the starter, but EVERYTHING else in the car appears to work fine... i tried in park and neutral to no avail either.... ive checked all fuses/relays/ the fusible link/ connections between alternator/battery/starter...... helppppppppppppppp!!!!!!!!!!!! thank u for your time rob
i'm too svxy for my car rob 92 ebony 4.44's rock !! |
Re: underhood wiring diagram?
That sounds like an engine/chassis ground......
You can find a diagram in the link in my signature either by viewing it on the web or downloading it and opening the .pdf labeled "system wiring diagrams". Hope it helps! |
yeah...i figured as such...thanks!!
i figured out my no-start trouble...the wire had slipped off the spade lug on the solenoid and i hadnt noticed....D'OH !!! right with the black wire i mentioned is a broken ground wire bolted to the firewall...it is unplugged and would SEEM like it should match up with the broken black/red...but it doesnt ... weird... ps...error 404 file not found...dang !!! linky no worky at this time...
kewl !!
thanks maaaannnn!!!!!!!!!!1
