Old 11-08-2006, 12:44 AM
dynomatt dynomatt is offline
6MT starter stud
I've sent Tom a PM, but until he responds, what do you guys do with the helicoil to fit the starter stud on the 6 speeds?
I've removed the 4EAT stud, but the hole in the 6 speed is a bit bigger, meaning you'd need to pack it out with something to get the stud to bite.
Also, is it easier to do with the 6MT out, or can it be done in the car...the only reason is I'm keen to get it in tonight if I can.
Thanks,
Old 11-08-2006, 02:53 AM
Sorry guys...this should have been in Mod Mania...my bad.
M
Old 11-08-2006, 04:58 AM
mikecg's Avatar
mikecg mikecg is offline
Send a message via AIM to mikecg Send a message via Yahoo to mikecg
I endedup using a bolt I had laying around that fit.
Old 11-08-2006, 06:39 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
M
Ask and Ye shall receive!
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 11-08-2006, 12:39 PM
Mike, a bolt? Did you bolt the starter on before you bolt the gearbox on? That could work I guess...
Old 11-08-2006, 01:12 PM
Speedklix's Avatar
Locker Link Solution
could you just tack a nut inside?
-edit-
How about reversing a lock washer too?
With the trans installed you can reach in and feed the bolt and washer through the hole, install starter and be able to apply minimum pressure to the threads to steady the bolt as you tighten the nut up.
Or just use a stud installer to steady the bolt while you tighten the nut down. That may be the best way.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 11-08-2006, 01:18 PM
mikecg's Avatar
No, the bolt I used was the correct threads for the hole. The tranny was already in the car when I had an issue, and the starter was already in, being held in by the other side. Assuming I understand what your saying, I had mine come out also. The hole on mine was threaded.
If your taking about something else, sorry I confused you.
