Old 01-29-2016, 03:08 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Relay 6 usage under the hood
I have just installed fog lights into the OEM area - see downunder for reason why....
I want to use the Relay 6 position in the under hood fuse box - since mine is not being used.
My question is what in OEM was this position actually used for?.
thanks
Steve in New Zealand
Old 01-29-2016, 05:38 PM
trophy956 trophy956 is offline
Re: Relay 6 usage under the hood
the list in my wiring does list 6 as unused ,OEM fog light relay was inside by the horn relay
Old 01-29-2016, 06:29 PM
SURTEESS's Avatar
Where is horn relay located ?.. in the foot well area ? or under the steering wheel area?
Old 02-01-2016, 05:13 PM
under the dash outboard of the brake pedal ,you will see the ecm and tcu
the horn relay should be red
Old 02-22-2016, 02:35 AM
SURTEESS's Avatar
in the 95 TSM it shows relay 6 as being used for fog lights......that is where mine now resides.
