98 Forester interference engine?
Last night one of my boss' friends towed in their 98 forester, when its started the engine makes a loud clanking sound, almost like rod knock. He verified that the timing was slightly off........ so is this engine interference type? Its the 2.5 liter on a 98 Forester.... thanks guys.
Re: 98 Forester interference engine?
Through 1996, all SOHC EJ251 engines were non-interference engines. They were run by a single timing belt driving both cams on both sides of the engine, and the water pump. Because they were non-interference engines, if the timing belt failed, these engines would not be destroyed. The oil pump was driven directly from the crankshaft and the water pump by the timing belt. Beginning in 1997, all DOHC and SOHC EJ engines are interference engines. If the timing belt fails, the engine will likely be destroyed or the valves and pistons will be heavily damaged. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-24-2009 at 11:28 AM. |
Those are the worst engines subaru ever made.
We were so happy with the 3.0 flat-six engine on our Outbacks. They had timing chains which never needed replacing and were non-interference.
Looks like our new 2010 Outback 2.5 will need watching again in this area. At over 50,000 miles a year, the recommended replacement interval will be here before I know it. .
Apparently according to the tech that redid the head gaskets, the timing is on, the belt didnt slip..... however the engine sounds horrible when started, similar to rod knock.... and apparently hes also claiming that the oil is ok and full.
What could possibly cause so much internal engine damage if the timing is correct and the oil level is ok? |
How come you didnt go with the 3.6 liter? I have one in my Tribecca, runs strong on regular fuel too!
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
All the EJ25's are interference. You won't find any that aren't.
You are correct.
I was thinking of the earlier EJ22 2.2 L Phase I engines. The little 4-bangers had 137 hp, and had dual exhaust ports, which made them non-interference. Later in production, 1995-1996, the late Phase I EJ22 was reconfigured for a single exhaust port, making it an interference engine. This continued into the EG22 Phase II engines, until replaced with the EJ25. .
and the SOHC 2.5 wasnt out till 1999
True. This is the EJ25 that does NOT have the typical HG problems of the early EJ25's.
