Old 05-18-2019, 07:29 PM
Jvan Jvan is offline
front right ABS speed sensor
According to the ABS monitor light under the passenger seat, I need to replace the front right ABS speed sensor on my 95 LSi. Checking online prices, it can run between $180+ to more than $220 plus shipping; Other Subaru ABS sensors can be $30. Does any one know if the ABS wheel speed sensor from another model Subaru can be swapped to the SVX. Since many Legacy and Nissan parts are used in the SVX, I'm hoping that a cheaper option can be found.
Old 06-04-2019, 08:04 PM
Re: front right ABS speed sensor
Didn't get any responses so I purchased a new sensor from the dealer. Can anyone tell me how to replace the sensor? Is it something that is just unplug and remove from the rotor?
Old 06-05-2019, 02:27 AM
irox irox is online now
Hi Jvan,
I've removed this a few times (and replace one completely once), it's not too much of a pain. There is a bolt holding it on the back of the hub, you'll need to remove that to get the sensor out. The hard part is getting the sensor out without damaging it, but since you are placing it you'll have luxury of not carrying about the old sensor (good practice to try and remove it without damaging it).
Once it's off you'll need to remove the bracket(s) that holds the cable out the way until you get to the plug. I forget if this one goes through the wheel well into the engine bay or not, I'm sure you'll figure it out.
Notes:
- Save the shim in case you need one for your new sensor.
- My wheel well was so caked in mud/dirt, I couldn't find the cable at first.
- Take care when installing the new sensor, try not to ban it or drop it.
- Download a copy of the Factor Service Manual and get the torque specs.
Good luck!
Ian.
