Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 06-30-2009, 04:00 PM
Re: What do you think of my new wing?
I spent way too much for my wing.
something something shopping cart...
Old 06-30-2009, 04:49 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-30-2009, 05:46 PM
Elliott's Avatar
Elliott Elliott is offline
I've started my prototype inspired wing. It isn't exactly like it, I could have done it closer, but I like this better.
Looking at the JDM wing, I don't believe it would be the best start for a prototype copy, overlapping the sides of the trunk lid is kinda ugly to me compared to the molded look of the prototype. I think the US stock wing will do so much better. From the moment I got the car, I thought Subaru mounted the wing in the wrong place, so I am fixing that and also molding it into the trunk lid to flow more like the prototype. Remember, this is not a copy, it is just inspired by the prototype, I took some liberties and am making it look good to me.
This is just the start, it will flow so much nicer once the glass work starts:
Once the glue has done its thing, I'll start molding it to the trunk lid with fiberglass. I did shave the sides of it down some, that thing is really thick, I took about 1/4" off that edge and still will not go through it if I stab it with a screwdriver. If it was about 1.5" forward, it would look more like the prototype.
I probably could have started with a different wing and got closer, but I had the stock wing already, I wasn't quite happy with it, I'm making it look better and am only out a little in materials.
Old 06-30-2009, 05:48 PM
Let me guess is that "glue" 143 Fusor?
Seth
Past subies:
Other toys:
Old 06-30-2009, 05:54 PM
Elliott's Avatar
It is from SEM, I don't remember exactly what it is, we've had really good luck with it in the past bonding fiberglass to fiberglass and fiberglass to steel.
Old 06-30-2009, 06:00 PM
It's pretty much the same stuff I use a work, I think LORD makes it. We make joke about 143'ing everything that breaks because it's strong stuff and sandable. I recently read a tsb for the new Ford F-150 Platnuim edition trucks where the platnuim trim on the tailgate would seperate and Ford said just to 143 it back on.
P.S. Here's an old thread of someone trying to make the prototype wing but with massive amounts of putty. http://www.subaru-svx.net/forum/show...prototype+wing
Seth
Past subies:
Other toys:
Old 06-30-2009, 06:07 PM
Elliott's Avatar
I can't remember which adhesive company it was, but one of them glued an engine together with something that is normally used for quarter panels and it made quite a few cross country trips before something started to give way. I don't remember exactly what they glued, but I know the heads were glued on and didn't have any bolts.
Yikes, we pretty much had the same idea, but his approach is so wrong it is actually hard to look at. The first thing I thought about was how far the wing was going to go back, it wasn't a even question of if I was going to do it, it was going back from the beginning.
Old 06-30-2009, 06:12 PM
Elliot, you should raise that wing a little bit from the back, the upper panel of the wing slopes downwards from the back. If you raise it by half an inch, it will look better and be positively functional.
Take it from a fellow fiberglasser
Old 06-30-2009, 06:15 PM
Elliott's Avatar
Too late to change anything, that glue is not going anywhere.
Old 06-30-2009, 06:28 PM
I know that...
Some day I am gonna fab a lighter version of the trunk lid out of FG. I dunno why Subaru made it so heavy in the first place. They could have always made a thin metal one instead of the two layered thick product.
BTW Elliot, did you break the tabs while removing the side panels?
Old 06-30-2009, 06:40 PM
Elliott's Avatar
That shape would not have worked with metal.
Haven't had the time or the need to pull them from my parts car yet. All of mine were broken off when I got the car.
Old 06-30-2009, 08:55 PM
McTaff's Avatar
McTaff McTaff is offline
Mr Soob
Can anyone post pics of both the prototype and JDM wings for comparison?
'07 Outback (Legacy) Pearl White > 3.0R Premium, stock (50,000km, Wifes daily driver. Owned from new) Not For Sale
'92 SVX Black on Pearl White > 6spd, DCCD on the way. (260,000km, My daily driver, 2 previous owners) Not For Sale
'93 SVX Black on Charcoal > Aftermarket rims.(250,000 km, Dad's daily driver, unknown owners) Not For Sale
'93 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (55,000km, 1 previous owner) Not For Sale
'92 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (144,000km, 2 previous owners) Not For Sale
Wife, Red Hot when riled > Treated like a princess. Minister For Finance, Domestic Affairs and Diplomatic Relations. Definitely Not For Sale
My Wanted List: http://www.subaru-svx.net/forum/show...178#post632178
Old 07-01-2009, 12:36 AM
You can check one of my previous posts, it has few links to the prototype SVX.
Old 07-01-2009, 05:22 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Moar pics Thus far I can't really tell what you've done to it, just moved it back a bit and glued it?
Old 07-01-2009, 11:35 AM
Elliott's Avatar
Yep, so far that is it, today I will start molding it in. I wanted to make sure the glue was fully cured before I put anything on top of it. The glue insures that I won't have cracking issues, I redrilled the bolt holes, but they are only good for holding it while the glue cures.
Also, when you mold the wing into the trunk like this, it won't be able to breathe unless you drill up into it from the bottom of the trunk. Hollow fiberglass needs to breathe, otherwise it will crack when the air inside heats up. I've seen cheap wings without air holes grow 1/2" in thickness just from temperature change.
