Sunroof adjusting nut??
I saw the previous post that the sunroof problem can be fix be adjusting the gold hexa. shape nut. But I as I open the sunroof, I cannot found any gold, hexa. shape nut or something cover a nut. I only found a cross type nut on each sunroof rail. Can anyone point me out where is it?? Thanks.
Re: Sunroof adjusting nut??
Is it inside the car or outside the car?? I think behind the dome lights is the rear view mirror. Do I need to take off the dome light first??
my sunroof doesn't close by itself on the right side sometimes. Could this fix the problem?
SVXtc -- I had the same problem with the sunroof dragging on the right side. Adjusting the nut didn't fix it. I found that one of the nylon rollers had come apart and a piece of the debris from the roller was causing one side to drag. Thoroughly clean your tracks and look for any debris. Also, a little silicone lubricant smeared on the rubber gasket around the perimeter of the sunroof will help.
I try to adjust the nut several times. But it still cannot fix the problem of opening. I still need to give it a push to open the sunroof.
