Old 07-05-2009, 11:07 AM
SomethingElse's Avatar
word words wording
Re: 11:1 CR Race/Street Engine build
Originally Posted by TomsSVX View Post
Remote mount electric water pump w/ aux cooling paths to cyl heads to try and repair the overheating issues tracked EG33's have had in the past
Next event I was going to run I had planned on installing a switch on the control side of the cooling fans so I could just flip thy switch for full fan function and try to prevent this......
Remote mount water pump sounds way COOLER!!!!
Is it the coolant pump/poor passage design causing these problems? Can you disclose any pics or diagrams?
Eric
Old 07-05-2009, 11:19 AM
shotgunslade's Avatar
shotgunslade shotgunslade is offline
I noticed that those who have tracked the automatic SVX do not seem to have had the overheating problems that us manual transmission folks have had. Harry (NewSVX) and Paisan have both tracked their cars without incident. Almost everyone who has tracked a manual car has at least had blowback into the overflow tank. I think this is related to the 6400rpm redline mandated by the automatic shift points versus the 7200 to 7500 rpm that manual drivers use.
Even Jack Laverty (Eg33 RS showcased here by RallyBob) has had a lot of overheating problems.
If overheating is related to high revs, I want to get good torque between 5500 and 6500 so I can use 7000 to 7200 as a shift point.
As for the cost, by the time it is all done, pistons, long block build, injectors, Hydra Nemesis, equal length headers, dual exhaust, it is probably going to be pushing $12k.
Old 07-05-2009, 12:55 PM
While this may help at low speeds, the fans can actually become an obstruction at high rates of speed and be detrimental to the efficiency of the cooling system. The electric pump is to increase flow and also allow the aux cooling I will be adding to this engine. It is hard to explain without having the engine in front of you, so lets wait until I can get pictures of it all finished
Old 07-05-2009, 04:26 PM
I read somewhere that the stock water pump of the SVX is extremely efficient, sometimes better than the aux electric pumps. Will the stock pump remain along with the electric pump or are you planning to delete the stock one?
Old 07-05-2009, 05:37 PM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Works for me. Looks like a killer build, can't wait to see what it will do!
Also, the parts vulture in me wants to know if you have two left over ACL bearings you want to get rid of.
Old 07-05-2009, 08:08 PM
nope, they go back on the shelf with the other couple of sets I have for future engine rebuilds.
Old 07-05-2009, 09:18 PM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
Sounds like a intresting build
Are you keeping it 3.3 or are you going to bore the block out a lil bit?
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 07-06-2009, 01:50 PM
A very slight overbore. Maybe a little over 3.4 ltr displacement.
Old 07-06-2009, 05:53 PM
When is this build estimated to be completed?
Old 07-06-2009, 06:19 PM
I am hoping to have the long block completed by the end of the month. Basically my hold up is getting the cams back from Web to measure needed shims and order them. Once that is done I will do the R&R of the engine and begin working in the water pump & headers.
Old 07-06-2009, 11:49 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Dan, its nice that you don't give up on this car.
I hope you'll get out of most of the fun on the track days after your build.
*looking forward to seeing the results*
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 07-07-2009, 04:33 AM
Dessertrunner's Avatar
Guys I think the cooling could be a big problem for our engine. We have a guy over here who has a racing buggy (think you guys call them sand rails) and it has a SVX engine. He can't keep it cool even though his radiator is about 2 times bigger then our PBR.
He just brought a multi flow radiator. Should hear by the weekend if it fixed the problem. It seems that we need to keep the coolet in the radiator for a longer time to get rid of more heat.
I am not going to race my car till I fix the heating issue.
Tony
Old 07-07-2009, 04:37 AM
I miss it on the track. The new roadster is too much like work. Very twitchy, very tail happy. Scary fast, but scary. Also, I loved being king of the hill when it rained, rather than the soaked guy in the little orange car sliding all over the place.
Have fond memories of good turns, especially after I got a handle on how to drive it. Looking forward to more of the same. Will need about 1000 miles to break it in, so it might be next season before I'm back out on the track.
Originally Posted by Dessertrunner View Post
Guys I think the cooling could be a big problem for our engine. We have a guy over here who has a racing buggy (think you guys caal them sand rails) and it has a SVX engine. He can't keep it cool even though his radiator is about 2 times bigger then our PBR.
Tony
Tony, what mods did he do on the EG33?
Old 07-07-2009, 05:00 AM
As I have tried to explain before many times and so have others, the overheating is not due to an insufficient radiator. When the needle is in the red, the coolant comming out of the radiator is still at ideal temp. It is a restriction/stagnation in the engine's cooling system. That is why I will be keeping the stock flow path and merely adding new ports to the cylinder heads for aux cold water inputs to keep the water from boiling and causing the spikes in water temp.
