Zymol Rubber Seal Conditioner
Major props for this product. I coated every rubber seal in the car with this and let it sit for a few hours. When I brought the car out for a drive, every evidence of wind noise was gone! I was getting a lot of noise and whistling but it all went away. And I was up to 65 on the highway in a strong cross wind.
The company claims to make the rubber feel like a dog's nose. I felt the rubber and I felt the dog's nose and I can confirm that it does indeed deliver on this claim. The next step is to put a thin layer of lubricant over the door seals to keep them from freezing together when we get freezing rain. It already happened once this season.
Re: Zymol Rubber Seal Conditioner
We had freezing rain twice already. This morning was brutal, about 3/8 of an inch of ice. It took me about 20 minutes to get in the car. The seals definately need to be dealt with.
I'm going to give the Zymol 24 hours to fully condition the rubber and then I am going to put a thin coating of Krytox lubricant on them.
Where did you buy those products? I usually go to Advance Auto Parts in Ogdensburg, NY.
I bought them on ebay. I think I may need more of the Krytox but, damn, that stuff is expensive. It may be overkill for what I am doing but I wanted to make sure I used something effective but inert. I also used it to lube up my door and hood latches and the door stopper thingies. The Zymol went a long way and I will have that bottle for some time.
Many members here use Sil-Glyde, a silicone gel available at many NAPA and Auto Zone stores, as well as Amazon HERE HERE is a better product description from the company's website. Just squeeze it from the tube and rub a small amount onto the rubber weatherstripping. it dries and leaves a slick, non-stick coating. I have been using it for years and never had a sticking problem. Hard to describe, but it works beautifully. Aredubjay turned me on to this stuff years ago. Search sil-glyde on the web to find where else it is available .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-26-2010 at 10:05 PM. |
