Old 10-25-2015, 07:34 PM
Jermz92 Jermz92 is offline
Post Speed sensor/ speedo??
Ok so I'm working on a 5 speed swap and ran into a couple problems
1st-the previous owner I purchased it from had already done the swap and the speedometer does not work and I was wondering what's the best way to wire the speed sensor
2nd-options to wire up the reverse lights as well
3rd-the dash lights do not work but the gauges work for the most part there is a big wiring mess under the dash. Does any one have a component location diagram to help I'm assuming that it has something to do with the rigged ignition switch with missing wires
4th-kind of unrelated but has anyone had problems with the rack and pinion leaking from the threades for the lines, I replaced a couple pinched lines and now power steering works but will leak out all the fluid daily quick (didn't work when I got it)
Long story short it was a poor instal from the previous owner and now swapped in a new transmission after the other one failed and kinda stuck at the point I was when I bought it. The transmission is out of a 03 Impreza RS any help would be appreciated
Old 10-27-2015, 01:18 PM
Re: Speed sensor/ speedo??
Get a hold of Phil (kingbobdole I think is hi name here) he has 5-speed swap experience, and wiring, general SVX /Subaru knowledge (he is in CO)
