Old 06-12-2010, 05:00 PM
Re: Electrical Issue
Originally Posted by kwren View Post
Would please type a little slower... Trevor apparently is having a little trouble keeping up.
Thanks,
Keith
Sorry Keith,
In spite of your flat earth friend, I always remain a day in advance of you. It is you who must keep up.
Old 06-12-2010, 05:07 PM
kwren's Avatar
kwren kwren is offline
Old 06-12-2010, 06:38 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
Thanks,
Keith
Hey, there's two of us in this thread...
Thank you everyone for your input, maniac it is!
Now it's just a matter of getting my money back..
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 07-07-2010, 02:44 PM
is it manic or maniac?
as far as the xmas lights go, i remember all of the lights on the bottom flickering regardless of color. now, only the red lights glow and only at a complete stop. is my alternator failing again?
Old 07-07-2010, 02:51 PM
Sounds like it, or the belt could be loose. When stopped, the engine is at it's slowest speed so the output of the alternator is greatly reduced.
Old 07-07-2010, 03:07 PM
interesting.
Old 07-07-2010, 04:45 PM
The symptoms described indicate an alternator fault which has been reported here many times. However the exact cause can be rather obscure because the symptoms are not always properly analysed and described. There is always a better understanding of each individual problem, if the exact trouble lights which are illuminated are specified.
The dash indicator lights test circuit, incorporates blocking diodes to eliminate a sneak circuit which would otherwise exist. In an event involving faults within the alternator rectifier network, alternating current is induced on line. As a result pulses of reverse voltage, pass the blocking diodes in the test circuit and energise the indicator lights.
It has been shown that testing battery voltage with a multi meter switched to the alternating current function, can usually disclose the presence of the unwanted current.
Mechanical or other faults involving the alternator, will not result in this exact symptom, which involves the failure of rectifier diodes within the alternator, but additional faults could exist in tandem.
