Timing Belt Failure
I recently got stranded due to a timing belt failure. I had my car towed to a sleazy mechanic who informed me that I had an interference engine and it was shot and I needed to replace my whole engine. I know for a fact he didn't check the valves, so how would he know this?
I was sure that my '94 SVX was a non interference engine, but I called Subaru who told me "It DEFINITELY was an interference engine." Has anyone had experience with a timing belt failure? Do I really need to replace my engine? My course of action is to replace the timing belt and hope for the best |
Re: Timing Belt Failure
It is not an interference engine. You could just replace the belt but most people replace the pulleys, seals, water pump etc. while it's apart.
There are kits on ebay for the t-belt, idlers and tensioners for about $170. Don't get the ones with the water pump included though. There have been problems with those. Get a water pump, thermostat and appropriate gaskets from the dealership. Also, if your engine leaks some oil, it might be a good idea to replace all of the front oil seals since you'll have everything apart that needs to come apart for that job. |
Wow, even the Subaru dealership told you it was interference??
The ignorance and subsequent bad information some folks give regarding our cars is staggering A new timing belt and properly aligned cams will make your car run just like before. Depending on how much you want to drop into the car, you can just do the belt.... but if you plan on keeping it id do as suggested and get the waterpump done along with the new belt, and new idler pulleys. The stealership charges an arm and a leg for the waterpump, but I can safely recommend A1 Cardone as it has lasted me 14,000 miles so far with no problems for around $50, as compared to what Subaru quoted me about $280. |
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Honestly, I'm not sure how many miles were on the belt. I bought it used and it has 149,000 now. I'm assuming they changed the timing belt once or never.
As the guys mentioned, get the timing belt kit and a new waterpump (150K on an OEM pump will definitely needs replacing soon) and if I might add a new thermostat. Check the hoses and clamps while you are at it.
In addition to the timing belt and idler pulleys, I would replace the following: Here are the parts, part numbers, List price and discount price. You should be able to get very close to discount price. Water Pump..21111AA033....$153.62..$117.06 Gasket Water Pump..21114AA051....$3.97..$3.02 Water Pump Seal..21116AA020 ....$3.50..$2.67 Thermostat..21200AA072....$15.95..$12.15 Thermostat Gasket..21236AA010....$3.43..$2.62 Less than $140.00 plus shipping or local tax. Highly recommend Subaru OEM new water pump and gaskets. .
BTW, I bought it locally for $35, replaced it and drove the car for 3 years until I left. I am really happy with it Part number is Gates T209 if anyone is interested.
Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
And 16 years
Since your timing belt actually broke I would venture a guess that it would be a safe bet that the belt was the original... Unless... you have developed a pulley problem that caused the belt failure. In either case I would personally get the kit with belt-pulleys, etc as well... but not the kit with the water pump. For me, that new pump would have to be a genuine Subaru pump. The belt-pulley kits currently on eBay are quality and should cause no concern on installing them on your SVX.
Good luck... Keith |
My 2 cents, I'm running 2 Import Experts water pumps with no problems. One has 20k the other 2k. BTW the way they are Prestone brand that come with the PCI kits on ebay.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
Keith |
As a matter of normal maintenance, I replaced water pump, idlers and adjuster together. The mechanic involved, who on the basis of evidence I trust, would not otherwise have guaranteed the job.
Subarus are a very popular car here in NZ, and all mechanics have adequate experience concerning their short comings.
