Old 09-15-2009, 01:37 PM
subeman90's Avatar
Soobologist
5 speed question
so i bought a tranny (05 impreza 5 speed) to start to get stuff together for my swap but it doesn't have stub axles sticking out of the trans. where the heck do they come from?
15 OBW premium w/eyesight
Old 09-15-2009, 04:50 PM
Re: 5 speed question
your Automatic. Just get a pair of new axles seals for the AT so you can install them into the 5mt
Old 09-15-2009, 06:35 PM
subeman90's Avatar
Soobologist
ok well that makes me feel better. I guess I'll just add that to the list of all the other isht.
oh well this should help someone else some day with a SEARCH!
Old 09-15-2009, 06:38 PM
if you searched you would have found the answer too
Old 09-15-2009, 07:48 PM
hi you see in 03 for the forester subaru changed the shafts ,and diffs
the DOJ or inner joint has the shaft machined as part of it
you have some work to do ,ill do a little on my side for you and see if you can swap the joints from a new style to the svx axle
i hope this helps
Old 09-15-2009, 07:50 PM
p/s the stub shaft seals from a auto diff wont work ,the new ones along with the carrier bearing holders have been changed also
Old 09-15-2009, 08:08 PM
I have done it. it works. The inner diameter of the seals seat is identical. The only change is that you can change the seal without removing the side plates like you did before. The auto stubs fit with auto seals plain and simple
Old 09-15-2009, 08:34 PM
tom if you done it thats great ,i did not think the out dia was the same
Old 09-15-2009, 08:40 PM
it would be great to be able to update to the new style with better boots and trunion bearing instead of ball bearing and taking out the movment of the doj on the stub shaft ,ill have to try to put one on one of my axles
Old 09-20-2009, 05:43 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
What, do you think Subaru knows how to build 5 speeds that don't work like crap? Just be happy you have one of the best shifting real SVXs on the planet and actually change your fluids in it properly, you'll get another 200k out of it! No need to join the hack'em up b/c I'm too cheap to keep my tranny running so I downgrade to a sloppy 5 speed brothers.
