Old 02-24-2008, 01:44 PM
Sir. Nate's Avatar
Sir. Nate Sir. Nate is offline
SVXtreme
Brake band adjusting
I'm adjusting my brake band, as per the instructions in the how-to. They state "tighten adjust screw, the back off 3 turns." Which way is tight? Right would be decreasing clearance, and left is tighter clearance. Do I increase clearance to tighten it down? I don't want the band strut to fall off inside the tranny by turning it the wrong way.
-Nate
'92 LS-L Pearlie
Old 02-24-2008, 03:01 PM
Sir. Nate's Avatar
SVXtreme
I adjusted it all the way out for tighter clearance, and it hits second gear for just a half second and then falls into 3rd. I guess the brake band is gone shot.
-Nate
'92 LS-L Pearlie
Old 02-25-2008, 03:57 PM
immortal_suby's Avatar
Thread Killah
clockwise = tight
you want to decrease clearance to tighten it down.
too loose allows shifting straight from 1st to 3rd - as you are experiencing.
Locker Link
2015 BRZ Limited 6MT
Old 02-25-2008, 06:25 PM
Sir. Nate's Avatar
SVXtreme
okay, I adjusted the brake band all the way in and it works now, but it's worn out pretty bad.
-Nate
'92 LS-L Pearlie
