Old 02-06-2007, 08:57 PM
Old Fogey
Question Did I do the right thing?
Wife was in SoCal last Weds-Sun visiting the kids and Grandson, and seeing her Sis up from San Diego. I was at home icing up a growler of Beerman's best Heffeweisen for the Bowl at some friends, when she called on her way home. About an hour later, just prior to my departure, she comes up on the Caller-ID, uh-oh!!
Says she's on the South side of the Grapevine just outside Castaic, by the roadside. Stopped cuz the Legacy sounded like it was dragging something, but nothing there. Now it won't start(click-). No overheating, so I'm still hopeful. Have her check for obvious signs, oil puddles, mess under the hood, etc and nothing shows. Subsequent try to start makes "Horrible" noise, aw $hIt!! Call CSAA for a flatbed to Subie dealer in Bakersfield, and once she arrives and have some friends there (whew! they're home!) on the way to pick her up, I head out to party.
Check in with dealer Monday, and I'm told motor is shot, most likely rod/bearing/bottom-end toasted. Car has 165K on her and now comes the dilemma. Spend some major dough on new short-block, used motor, or look for a new ride. Asked her, to be told "NO CAR PAYMENT!" and willing to drive it for a couple more years b4 getting something quieter(grown up car).
So, long story semi-short: my shop guy is leaving 7am Weds with car trailer to fetch it, and her, on my dime, about 300mi each way. New short-block, re-use heads with 40K old valve-job, surfaced and cleaned up, new T-belt, Exedy clutch and "snout kit', gasket set, H2O pump, etc etc. Bottom line $5K plus transportation. We both love the car and she looks 3 yrs old, not 9, check my locker. Dumb? Sentimental? Mental? Realistic?Remember, this is California, and dealer was guessing $6-7K.
Glenn
Old 02-06-2007, 09:32 PM
Manarius's Avatar
Manarius Manarius is offline
I guess the T-Belt snapped and toasted the top end? Or did it throw a rod? Either way, a rare occurrence. I'd have just swapped the entire engine for 2k and been done with it.
That is a smokin' wagon though.
-Jason
-Obi Wan Kenobi
Old 02-07-2007, 12:48 AM
subi-crosser's Avatar
Now with more color
Glenn
Some of the best subi's I ever met were on the way to the 'used parts' counter.
Spend the money if the car was what you wanted. I am sure that your guy will have a lot different numbers than the dealer!
I bought a $9,500 car with 'head issues', for $4,500 and fixed the prob for less than 700$ three years later I had to put wiper blades and a battery in it.
Jerry
Old 02-07-2007, 05:22 AM
mikecg's Avatar
mikecg mikecg is offline
I vote for importing a B4 Blitzen motor and installing it.
Twin Turbo's baby.....
Old 02-07-2007, 06:47 AM
Pick up a used 1st gen EJ22 and drop in it, it has a little less power, but is pretty much bullet proof...I can find them for as little as $200....just look around...
That's what I'd do...
Old 02-07-2007, 12:23 PM
Subafreak's Avatar
Superbeast
Or.........EJ22T
Old 02-07-2007, 03:01 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Originally Posted by Subafreak
Or.........EJ22T
+1
2006 Steel Gray WRX TR (sold)
Old 02-07-2007, 03:27 PM
Speedklix's Avatar
Locker Link Solution
Or.........EJ22T
+a zillion
There are lots of other things I would spend the money on engine-wise.
I'd love an excuse to drop more boost in the beater!
But if you just want a reliable car, the advice I tend to give is....
If you can make what you currently own better than anything you could buy with the same funds.... keep the car!
If you just want it to last a few more years... drop in a low-miles with a new rear seal and oil pan gasket and be done with it. Do the rest of the service if the engine works out, the hard to reach parts are already done.
I also love the idea of no car payment, although after the toyotas "fit" the other night I see a NEW subaru in my future for the girl. It is times like this I wish I owned at least one automatic I'm not in the position to buy new with cash right now
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 02-07-2007, 07:14 PM
Boxer6SVX's Avatar
Boxer6SVX Boxer6SVX is offline
Dont Drink and Drift
You can find amazing cars with plenty of life in them for little cash. I bought a 1988 Honda Prelude 2.0S 5 speed with 97k miles for $450. It just needed a radiator and water pump. Replaced the timing belt while i was at it and for less than a grand she was good as new. Id drive it anywhere. Given since owning it I have put a B20 from a CRV in it and a small turbo mounted to a pretty crude made manifold but its just a toy, not a daily driver... Hell, It doesnt even have an intercooler =P
It sounds like a great car and if all it needs is another engine then find another identical to it with low miles, tinker with a few mods, drop it in, and be on your way. Its beater, gotta maintain reliability AND when you do sell it or trade it you'll never get your money's worth from dropping in a high performance EJ22T in it. IMO, for a beater, stock is the way to go.
1995 850Ci
1988 Prelude~ B20 swap
2006 Mustang GT (RIP)
Old 02-08-2007, 06:35 AM
Old Fogey
Thanks for all the feedback SVX'ers. The idea of an EJ22T has been discussed with the "daily driver" wife previously, and may have been feasible when the car was running. However, that's not the case, and the car is our "traveler" when big items need to be ferried to the kids, parents, etc, and her "dependable" transportation. Guess it boils down to time, and we don't really have any. This car has to be returned to service asap, or she'll want to use mine.
The car and wife are safely home as of last night, thanks to the shop owner's brother and a 12 hour round trip, in the rain. Kudos to Bill!!! Short-block will be here Fri and the fun begins. Just hoping nothing is found amiss with the heads when the old mill comes apart today. We discussed our situation last night over dinner and believe we've chosen the most practical and realistic path back to having solid, safe, daily transportation back in her hands. We love the little battle-wagon, and I'll continue to tinker with her for a few more years. Again, thanks for your feedback.
Glenn
Old 02-08-2007, 01:10 PM
Boxer6SVX's Avatar
I for one LOVE that model of the Legacy... I think theyre gorgeous really =) Glad to see youre keeping it around and not sending it off to the yard. KUDOS for that!!! Hell you'll get another 100k out of it with another short block!
1995 850Ci
Old 02-09-2007, 06:36 AM
Old Fogey
Thanks man! We had a 91 LS Wagon previously, and the BD/BH body style just knocked me out when introduced. I had to have one, and this one was being sold by a Subie used car Mgr that had her since new, loaded up. He commuted about 125mi a day, so the mileage was high(80K) when I bought her in 2000. I was thinking more like another 150K!!!
Glenn
