Old 07-21-2005, 12:07 PM
Tony117s's Avatar
Tony117s Tony117s is offline
Send a message via AIM to Tony117s Send a message via MSN to Tony117s
Word of warning
Never let your battery cables get loose, it fried my alternator >.<
[B]Tony
'95 Polo Green SVX L AWD 62k
'05 Ebony Pearl GT LTD Cobb Stage 1, Tein Coilovers, GFB BOV, Pzeros 6k
'00 Green Forester S 78k
Old 07-21-2005, 12:48 PM
red95svx
Yep. This is why the old mechanics trick of pulling off a battery cable while the engine is running to "see if the alternator is good" is a no-no for modern cars. You're lucky the voltage spike didn't kill your ECU. You can not take the battery out of the electrical system of a car while it is running....but you can on an airplane. For safety reasons their engines run completely independant of the battery and alternator (once started of course).
Old 07-21-2005, 02:25 PM
I once had a loose cable and I noticed because I started popping headlights. Also the running voltage was getting higher (almost 16V!)
Old 07-22-2005, 01:57 AM
94svxred 94svxred is offline
Very interesting I did'nt know that about the battery thing . I'm going to check mine ASAP
Old 07-22-2005, 02:03 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Originally Posted by red95svx
Yep. This is why the old dumbass' trick of pulling off a battery cable while the engine is running to "see if the alternator is good" is a no-no for modern cars. You're lucky the voltage spike didn't kill your ECU. You can not take the battery out of the electrical system of a car while it is running....but you can on an airplane. For safety reasons their engines run completely independant of the battery and alternator (once started of course).
Fixed your quote. No 'good' mechanic would have ever done this on any alternator equipped system.
Old 07-22-2005, 02:45 PM
thundering02's Avatar
Giong back to the beaters...
However on a side note If you pull the Jumper cables off and it dies immediatly then you know you have problems. did that once little econo box after looking around I still wasn't going to pay the 500 he wanted for it
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
Old 07-22-2005, 08:32 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Amen! The resulting arc is what makes flashbulbs flash bad juju!
Dave W.
______________________________
1996 Redd
