Old 07-24-2003, 09:40 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
i had the speedo saying 145 once...
and i don't think that the speedo in the svx is off
how do you ppl know that your speedo is off?
SV What?
Old 07-24-2003, 09:46 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
rob has a GPS, it gives you pinpoint accuracy for speed.
I hit 145ish once, she was starting to slow down a bit so i got off it.
phil
~Phil
Old 07-24-2003, 09:53 AM
alacrity024
i think the fastest i've had mine is 125mph indicated..
there aren't very many straight roads around here
-adam
Old 07-24-2003, 10:10 AM
mbtoloczko's Avatar
sans SVX
Originally posted by Porter
I've had mine up to 145, but the previous owner had a picture of the speedometer pegged at 160 on a trip across Arizona. Apparently his GF took the shot. She was cute, too.. I met her.
Wow. That's a cool girlfriend. I'm happy when my girlfriend simply ignores the fact that I'm driving 110 mph and doesn't tell me to slow down. :-)
Mychailo
Visit my locker
Old 07-24-2003, 11:31 AM
wawazat??'s Avatar
Yeah, I'm still around
That was in Pennsylvania, right?
Originally posted by mohrds
I've had mine up to 75MPH once. That's way too damn fast!!
Doug
While it was on the back of a flatbed?
Down to none
Old 07-24-2003, 11:40 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: That was in Pennsylvania, right?
Ouch
That was a low blow. Just wait till I have my 5 speed done before yours is
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 07-24-2003, 01:38 PM
SHISVX SHISVX is offline
Re: Re: That was in Pennsylvania, right?
Ouch
Doug
that is the only kind of blow ppl can get on you Doug....you are a tall one!
Kelli
Previous owner of the
Princess Pearlie "Dimples"
as of 8/6/03
1992 LS-L Pearl 124k
"Yeah, that thingy!"
owner of the new 1992 LS-L Pearl "Susie"
I am a pessimistic optimistic. I think the worst is going to happen, that way when it does, i don't feel as bad, but if the best happens, i am twice as happy.
Old 07-24-2003, 02:51 PM
mohrds's Avatar
Re: Re: Re: That was in Pennsylvania, right?
Kelli
Shhhhhhhhh!
You wern't supposed to tell anyone that. We don't want Amy to find out.
1994 LSi (4/93)
2000 Ford Excursion
Old 07-24-2003, 02:59 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Most speedos are pretty accurate......up to about 30mph. After 60mph, they are usually 5-10% off.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 07-24-2003, 03:11 PM
Chicane Chicane is offline
Anti-BS Vigilante
I don't know why people keep asking if its off 'up or down'. I've said this twice, in this thread, that when the SVX speedo reads 70mph, I'm actually only going about 65.5mph. Hence, the speedo is OVERRATED. If you think you're going 120mph, you're probably doing 114ish.
- Rob
Old 07-24-2003, 05:40 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
The fastest I've ever gone was 80-90.
Yea my speedo is overrated. Everytime I pass one of those police speed sensors that tells you your speed, it says I'm going like 37 when the needle says around 40.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 07-24-2003, 08:12 PM
Mine has always been right on. Police Speed sensor always the same as my speedometer. Just depends on the car i suppose. This is a common problem with all cars, it isn't like its an svx specific problem. Just happens
Old 07-24-2003, 08:55 PM
Subafreak's Avatar
Superbeast
As stated in other threads an unconfirmed 145mph up hill too.
Next time I will do it with a GPS holding copilot to please the sceptics.
Old 07-25-2003, 07:27 AM
CigarJohnny's Avatar
- Rob
Actually, Rob, this is the first and only time you mentioned that in this thread so far.
Aside from that you are not necessarily correct. Even when comparing the same rated tire size, each manufacturer's version of that rated size will be off from the rest by some amount, larger or smaller. That alone will cause a difference in actual speed compared to indicated speed. We already discussed in an older thread how just 4lbs difference in air pressure between front and rear tires can cause a drastic difference in RPM's a tire makes over a given distance. Add that factor in with the slight differences in manufacturing specs between brands compounded by tread wear differences and you have the recipe for widely varying accuracy in speedometer readings and the faster the speed the greater the inaccuracy. Your particular tire brand, wear and pressure cause your SVX to read optimistically. Some one else may actually read pessimistically depending on his combination of variables. By just increasing the pressure in your tires you might find that you could get the indicated speed to be dead accurate.
Besides, if what you say were true the folks who like to bust on your SVX for being slow would really have reason to pick on you for it being even slower than they thought!
Old 07-25-2003, 01:37 PM
_-DejaVu-_
Nothing too extreme
125 I believe.
I had a picture of the speed posted on here, but I did loose the original pic
Would like to go faster, but my car isn't in too good of shape right now
Deja
