Mirror select illumi bulb
Subaru SVX LSi `95 |
Re: Mirror select illumi bulb
The mirror switch DOES illuminate. The four little white arrows on the black cicular disc light up a soft green when the kights are on.
The word MIRROR and the L/R letters over the sliding switch do not illuminate. Members have tried to take them apart and replace the bulb, but it is a tricky process. Much easier to get a new one from subaruparts. Gray 83071PA020MD $59.06 Beige 83071PA020DO $65.41 See this thread: http://www.subaru-svx.net/forum/show...tch#post106595 and this one: http://www.subaru-svx.net/forum/show...ror#post496045
And, for those of us who don't have $60+ to blow on a switch just for some lights, replacing the bulbs is a fairly easy process.
You buy the bulbs from radioshack, cut the wires shorter, and re-use the green caps from the old bulbs. Radioshack item #272-1092
Re: Mirror select illumination bulb
