ATF flush vs. drain
Hi all, I need little help from you. Maybe I did not feel exact difference between flush and drain. My tranny was rebuilt couple months ago but was filled up with some Valvoline semi-synthetic ATF insted of Mobile 1 I wanted and insisted (you know some mechanics are silly :-((() It has some 2000 kms on it but I will want definitely switch to fully synthetic. So question is what is RIGHT procedure for me? Just to let drain it out and fill it with synthetic? Or what exactly mean FLUSH. Thanx for help.
Peter |
By just draining the fluid yoy only change about 1/3 of it. You only change whats in the pan, but most of the fluid is still in the lines, cooler, valves, and tourq converter. So flushing is always the best way to go especially if changing fluid types.
OK so what is the right procedure?
Peter |
Do the flush!
How exactly do you perform the flush?
-Mark (I just couldn't resist!) (always the smart a$$......... ) |
Definitely helped the wheel bearings :-) If you just drain the ATF from the sump, you get of ATF 1/3 out. If you drop the sump and pull a line that begs to be pulled, you get another 1/3 of ATF out in an hour or so (drips slowly). The flush is different from the drain because with flush they disconnect the cooler line, let the discharge line drain and feed the new ATF into return line to transmission. They promise to replace all ATF, but the catch is, you can't drain all old ATF first and fill new next, you can't leave running transmission empty. You have to actually supply new ATF while the old one is draining. The new and old ones mix in the process. Flush is more expensive then drain, but I'm not sure you achieve more than 2/3 of ATF replacement with it. |
