Old 01-26-2010, 03:06 PM
No power steering
I had stiff low speed steering . I changed the fan belt and it was perfect. ButThis morning I went to drive the car to work and it has no power steering . I checked the steering fluid it was empty . I filled it and it worked for 5 min and all the fluid ended up on the ground under the car back behind the driver side front wheel just below the nos sensor. Did I blow a rack or a seal or a hose . What you think. Local Subi place want $1,060.00 to repair . If the pump is ok. I can't find a seering Rack at a local parts store ... HELP
Old 01-26-2010, 03:16 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: No power steering
If you're lucky it's just a split low-pressure hose. That's what happened to me. Put some fluid in, run the engine and look carefully where it's spurting out from.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 01-26-2010, 03:23 PM
It is shooting out all the way to the right way back near the firewall just above the ware that hooks to the NOS sensor... as I said it was working great the day before I just changed a front 1/2 shaft and all the brakes and saw no leaks. I never lost Power steering fluid before. Where do i get the new hose? the fluid is pouring out as fast as i pour it in.
Old 01-26-2010, 04:14 PM
dennyo dennyo is offline
if i'm not mistaken the only flexible hoses would be on the passenger side. steel lines go to the pinion housing.maybe a seal on the rack?
Old 01-26-2010, 04:23 PM
Is the rack seal replaceable ? Where can I get a new rack? Besides Subaru? Or is there another rack I can use
Old 01-26-2010, 10:10 PM
I had my power steering rack and both hoses replaced months ago. I was out of town, so my dad ended up paying the ~$1000 to fix (at a Nissan dealership). Then I saw a few months ago that there were rebuilt racks for sale, but I can't remember from where. I think it was around $400. Point is, keep looking.
Also, you should try not to drive it without power steering fluid, it can burn up the pump.
Old 01-26-2010, 10:52 PM
Gamesy's Avatar
Gamesy Gamesy is offline
i believe i saw some on ebay from parted out SVXs
Old 01-27-2010, 12:20 AM
If you have an LSi or similar model with the leather seats, sunroof, etc. I have a steering rack for the speed sensitive steering. PM me if that is your problem and you are interested. Otherwise, just find where the leak is coming from.
Old 01-27-2010, 02:34 AM
I am not sure what rack I need . All I know is the fluid shot out of it as fast as it went in. and it was foaming. Is it hard to change a rack? is it hard to change seals ?
Old 01-27-2010, 02:47 AM
umm, not horrible, but not easy to change out the rack And i'm not sure if the seals are replaceable separate to the rack, I'm sure someone on here should know.
I looked in your profile and you have a 92 and you have it listed as an LSI, but in 92 they actually had LS and LS-L. If your car has the factory sunroof, its an LS-L and would need the rack with the solenoid for the speed sensitive steering.
edit; looks like the seals should be able to be ordered and replaced separately from the diagrams...
Old 01-27-2010, 05:21 AM
SomethingElse's Avatar
word words wording
clean it off, put the car in the air, start it, look for leaks.
If you dont want to do that then start with all new o-rings on all of the pipes (they get brittle and crack/deform) then bleed and test drive.
If your rack is still wet then more than likely it will need to be replaced.
Eric
Old 01-27-2010, 05:30 AM
dcarrb dcarrb is offline
This was the first Google hit I clicked:
http://www.car-stuff.com/mmparts/sub...ring_rack.html
That said, I'd bet you got a blown line. Leaking as badly as you describe, it shouldn't be hard to find.
dcb
Old 01-27-2010, 03:02 PM
dcarrb you win the prize Looking at line # 27 on the diagram. This is a small steel line that runs along the bottom of the rack from one end to the other . Right where it bend up to go to the driver side just above the NOS sensor there is a pin hole . I ordered the line from mother Subaru $17.00.. For now we wrapped a piece of rubber hose around it and squeezed it on with a hose clamp. Got a very slight drip but should hold until i get the part on Monday. My question is have you ever changed this pipe and how in the heck do you get to the fittings on the driver side of the rack? thanks for all your help you guys are great support.
Old 01-28-2010, 05:07 AM
I've had a rack changed but deemed this a job best done by my trusted mechanic. Hopefully someone else can offer advice.
dcb
Old 01-28-2010, 06:14 AM
The rack is GOOD. Steering is back to normal with the hole plugged. just need to change out the rusted pressure line. looks like it is going to be hard to remove one side.
