No power steering
I had stiff low speed steering . I changed the fan belt and it was perfect. ButThis morning I went to drive the car to work and it has no power steering . I checked the steering fluid it was empty . I filled it and it worked for 5 min and all the fluid ended up on the ground under the car back behind the driver side front wheel just below the nos sensor. Did I blow a rack or a seal or a hose . What you think. Local Subi place want $1,060.00 to repair . If the pump is ok. I can't find a seering Rack at a local parts store ... HELP
Re: No power steering
If you're lucky it's just a split low-pressure hose. That's what happened to me. Put some fluid in, run the engine and look carefully where it's spurting out from.
It is shooting out all the way to the right way back near the firewall just above the ware that hooks to the NOS sensor... as I said it was working great the day before I just changed a front 1/2 shaft and all the brakes and saw no leaks. I never lost Power steering fluid before. Where do i get the new hose? the fluid is pouring out as fast as i pour it in.
if i'm not mistaken the only flexible hoses would be on the passenger side. steel lines go to the pinion housing.maybe a seal on the rack?
Is the rack seal replaceable ? Where can I get a new rack? Besides Subaru? Or is there another rack I can use
Also, you should try not to drive it without power steering fluid, it can burn up the pump. |
This was the first Google hit I clicked:
http://www.car-stuff.com/mmparts/sub...ring_rack.html That said, I'd bet you got a blown line. Leaking as badly as you describe, it shouldn't be hard to find. dcb |
dcarrb you win the prize Looking at line # 27 on the diagram. This is a small steel line that runs along the bottom of the rack from one end to the other . Right where it bend up to go to the driver side just above the NOS sensor there is a pin hole . I ordered the line from mother Subaru $17.00.. For now we wrapped a piece of rubber hose around it and squeezed it on with a hose clamp. Got a very slight drip but should hold until i get the part on Monday. My question is have you ever changed this pipe and how in the heck do you get to the fittings on the driver side of the rack? thanks for all your help you guys are great support.
I've had a rack changed but deemed this a job best done by my trusted mechanic. Hopefully someone else can offer advice.
dcb |
The rack is GOOD. Steering is back to normal with the hole plugged. just need to change out the rusted pressure line. looks like it is going to be hard to remove one side.
Power steering is fixed . Had to have Subaru do it. My friend was tied up for a few days. Took them 34 min I saw a time sheet $95.00 and I gave them the part. Reason #1 Y U must work on your own car. Oh forgot that included the topping off of ATF.
