Old 12-23-2009, 01:53 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Memory dump of ECU
Sorry. I'm an idiot. Here you go.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-25-2009, 02:02 PM
RoughSilver92 RoughSilver92 is offline
Nice.
Now I am slightly stuck with these eor commands. I've looked it up in the software manual, but the explanation doesn't make it any clearer for me. May as well make sure about the sbc also.
00E22D A422 ldy dp + 0x22 ; Read from A/D successive approximation register
00E22F 98 tya
00E230 38 sec
00E231 EDD411 sbc ax, 0x11d4
00E234 B004 bcs 0xe23a
00E236 49FFFF eor ax, #0xffff
So here the tps value from the A/D converter is loaded to index register y.
It is then transferred to register a.
The carry flag is set (C=1).
The value stored at 11d4 is subtracted from register a.
If the result is greater than or equal to zero the program branches to e23a.
I know this much.
With the carry flag set does it also subtract 1 from register a (ie. A=A-(0x11d4 +1))?
What does the eor compare? We have the value in register a and the hex value ffff, but what about them? There doesn't seem to be enough values to do anything with.
It looks like the majority of the eors use #0xff or #0xffff. I don't know what the significance of this is. Right now it is just an observation.
Old 12-25-2009, 04:07 PM
b3lha's Avatar
Phil & Belha
Originally Posted by RoughSilver92 View Post
Nice.
00E22F 98 tya
00E230 38 sec
I know this much.
Very good work Andy. I'm impressed.
On this type of processor, you have to set the carry flag before a subtraction in order to get the right answer. If you look through the code you'll see an SEC before every SBC.
I can't explain it very well, but the reason is that the subtract instruction is designed so that when you are subtracting 16bit numbers, you can do it in 2 chunks of 8 bits at a time. The carry flag stores the sign of the result of each subtraction and it gets fed into the next stage of the subtraction. There's an example of this at EC68 where it subtracts a 16 bit value at 1098(and 1099) from a 16 bit value at 1096 (and 1097). But It's not really important to understand how that mechanism works, as long as you can recognise when you see it.
EOR, also known as XOR, is a boolean "exclusive-or" operation. It means either/or but not both. If you want to XOR two 8 bit numbers, you line them up on top of each other and calculate each column separately. The result is 1 if the bits are different and 0 if they are the same.
11000011
10101110
01101101
An XOR by FF, in the case of a byte, or FFFF in the case of a word, is the same as a NOT operation. Every zero will be changed to a 1 and every one will be changed to a zero.
This piece of code here:
Code:
00E239    3A            inc     ax
Does a NOT of AX register and adds one. In "two's-complement" arithmetic, this is how you convert a negative number to a positive number or vice-versa.
For example:
11111011 is -5. If you XOR by FF (11111111) you get 00000100 which is +4. Add 1 and you get +5.
So the code is saying, do the subtraction, and if the result is negative, convert it to positive. If the result is positive then it jumps over that bit of code and continues with the positive value.
I hope that makes sense.
Old 12-26-2009, 12:28 PM
That makes perfect sense. Sorry to bombard you with these big chunks of code, but I think they can be summed up easily and I want to verify I have the fine details correct as it seems a little strange.
Code block address: E208 Length: 110 M:1 X:0 called by: E383
00E208 AE3610 ldx 0x1036 ; Call target from E383 ; TPS_Voltage
00E20B 8ED211 stx 0x11d2
00E20E 342008FC bbc #0x08, dp + 0x20, 0xe20e ; Read from A/D control register, Branch target from E20E
00E212 A622 ldx dp + 0x22 ; Read from A/D successive approximation register
00E214 642004 ldm #0x04, dp + 0x20 ; Write to A/D control register
00E217 8622 stx dp + 0x22 ; Write to A/D successive approximation register
00E219 D8 clm ; m:0 x:0
00E21A 8A txa
00E21B 38 sec
00E21C EDD411 sbc ax, 0x11d4
00E21F B004 bcs 0xe225
00E221 49FFFF eor ax, #0xffff
00E224 3A inc ax
00E225 8D0410 sta ax, 0x1004 ; Branch target from E21F
00E228 34200800FB bbc #0x0008, dp + 0x20, 0xe228 ; Read from A/D control register, Branch target from E228
00E22F 98 tya
00E230 38 sec
00E239 3A inc ax
00E23A CD0410 cmp ax, 0x1004 ; Branch target from E234
00E23D B001 bcs 0xe240
00E23F BB tyx
00E240 8ED411 stx 0x11d4 ; Branch target from E23D
00E243 8A txa
00E244 4A lsr ax
00E245 4A lsr ax
00E246 F8 sem ; m:1 x:0
00E247 8D8C12 sta al, 0x128c ; SM_TPS
00E24A D8 clm ; m:0 x:0
00E24B 8A txa
00E24C 8D3610 sta ax, 0x1036 ; TPS_Voltage
00E24F F8 sem ; m:1 x:0
00E250 A24E10 ldx #0x104e
So here it is basically just reading the tps value from the A/D converter twice in a row and comparing it to the previous tps value (11d4). It stores the difference (absolute value) of the first read/comparison at 1004. It compares the difference (absolute value) of the second read/comparison with 1004 and stores the TPS value corresponding to the smallest difference at 11d4. Then the value is converted to 8 bit and stored at 128c(SM TPS). The value is stored in 16 bit at 1036(TPS volts).
I am doubting my understanding of the carry flag here. I would assume that the program would want the bigger change, but the way I read it if the second read/compare is greater than or equal to the first the program skips over the command to transfer the contents of y (second read/compare) to x and stores the tps value corresponding the first (and smaller change) tps value.
[QUOTE=
00E253 2C2610101E bbs #0x10, 0x1026, 0xe276 ; Errorflags 1 ; TPS Error
[/QUOTE]
I will take the easy route here and I will say that the program has detected a fault with the tps and the bit corresponding to a tps error has been set.
Code block address: E276 Length: 9 M:1 X:0 called by: E253
00E276 AD238B lda al, 0x8b23 ; Branch target from E253
00E279 0C251001 seb #0x01, 0x1025
00E27D 800D bra 0xe28c
Code block address: E27F Length: 23 M:1 X:0 called by: E270
00E27F 2C1E102012 bbs #0x20, 0x101e, 0xe296 ; Branch target from E270, Branch target from E274
00E284 0C1E1020 seb #0x20, 0x101e
00E288 1C251001 clb #0x01, 0x1025 ; Branch target from E296
00E28C 9500 sta al, dp + 0x00 + ix ; Branch target from E27D, Branch target from E292
00E28E CA dex
00E28F E04410 cpx #0x1044
00E292 D0F8 bne 0xe28c
00E294 8040 bra 0xe2d6
So here I believe a default 8 bit value (hex 14 if I read it right) is loaded from the rom to A.
bit 01 of 1025 is set and the program branches to e28c where e28c-e292 is executed 11 times total(104e-1044). During this loop the default value (in this example) that has been loaded into A is stored 11 times somewhere (dp + 0x00 + ix). I am pretty sure that the 104e-1044 makes up the ix portion of the equation, so is it just 104e-1044 that the value is written to?
00E2D6 8D4410 sta al, 0x1044 ; Branch target from E294
00E2D9 8D8512 sta al, 0x1285 ; Write to RAM: TPS
00E2DC 8D1840 sta al, 0x4018
00E2DF 60 rts
Cakewalk. Store the value in A at 1044 (seems redundant if my guess at where A is being stored above is correct).
Store the value in A at 1285.
Store the value in A at 4018.
Return.
Old 12-26-2009, 12:36 PM
That code came out pretty hard to read. I meant to mention that bit 01 at 1025. It seems like some sort of indicator that a default value has been loaded, but I don't see anywhere else in the program where that bit is specifically looked at. Main things making me scratch my head are the dp + 0x00 + ix and if i interpreted the carry flag correctly.
Old 12-26-2009, 04:04 PM
b3lha's Avatar
Phil & Belha
I don't really understand how the A/D converter works, except that it somehow converts an input voltage to a binary number. If you want to know, read chapter 9 of the 7733 User Manual on the Renesas site. It's not exactly the same CPU as ours, but it is similar.
Code:
http://documentation.renesas.com/eng/products/mpumcu/e7733um.pdf
You are exactly right when you say that
You are almost right about the next bit too. The ECU stores a history of the last 11 TPS readings between 1044 and 104e. This is so it can tell if you are increasing or decreasing throttle and how quickly you are doing it. It uses this information for things like "tip-in enrichment".
It looks to me as though bit #20 of 101e indicates whether the history buffer has been initialised. If the history buffer has not been initialised, then it is filled with the TPS value, or a default value if the TPS error flag is set. I think you are right that bit #01 of 1025 indicates whether the value is real or default.
If the buffer has already been initialised, then the code at E2C6 shifts it along one byte and then the new value is inserted at 1044.
Phil.
Edit: I forgot to mention, the value of dp is always 0 on this system, so you can ignore it. "sta al, dp + 0x00 + ix" just means " store AL at address 0+X"
Old 12-26-2009, 05:24 PM
Thanks Phil
Great info as usual. I didn't realize that the comparison thing that was going on there was part of the A/D logic(?). I guess in retrospect it doesn't matter how it chooses the value that the program uses. What is important is how the value(s) it does choose interact with the rest of the program. I need to try to stay focused on that. Just from what I have had a good look at so far I can see I should be able to find more things to label, like 1243 and 12c8 seem to hold either default values or (TPS Volts) dependent on certain conditions. I think I have a long road ahead of me breaking down each function into simple if/else statements then trying to pull it all together and make like a flow chart describing the program.
About these little Indians:
00008660 80 80 FF 66 00 0A 00 64 82 14 0A FF 02 24 02 02
In the chunk of code below when loading and adding the 16 bit values conventional thinking says 8663 contains 66 00 or 26,112(I think). Since it is little endian is it really a 00 66 or 102? Same with adc ax,8665, is it really adding 00 0a (10) or 0a 00 (2560)?
00E323 D8 clm ; m:0 x:0
00E324 AD6386 lda ax, 0x8663
00E327 8DC812 sta ax, 0x12c8
00E32A 18 clc
00E32B 6D6586 adc ax, 0x8665
00E32E 8D4312 sta ax, 0x1243
00E331 F8 sem ; m:1 x:0
Old 12-27-2009, 01:46 AM
b3lha's Avatar
Phil & Belha
8663 is 0066
8665 is 000A
At some point you'll discover a nasty little trick in the code where they write a 16 bit value to an address and then never use it. Sometimes, they just read the high byte from (address+1) and use that instead of the whole 16 bits.
There's also some 24-bit numbers. Again, these are stored low byte first, high byte last.
Old 12-27-2009, 01:07 PM
Sweet. I have run into something like what you are talking about here:
00E25F A90000 lda ax, #0x0000
00E262 89090058 mpy #0x5800 ; Branch target from E25D
00E266 8928 xab
00E268 8D0410 sta ax, 0x1004
00E26B F8 sem ; m:1 x:0
00E26C 42AD0510 lda bl, 0x1005
00E270 F00D beq 0xe27f
I didn't include it but if A is greater than or equal to 0 e25f is skipped and the value in A is multiplied by hex 5800. So it looks like either A or hex 0000 is multiplied by hex 5800. Then the xab followed by the sta ax, 0x1004 is swapping A and B (necessary because of the way the processor works, I suppose), putting the most significant 16 bit value in A and storing it at 1004. Then the most significant 8 bit value is loaded into bl from 1005. The program then branches to e27f if the zero flag is set, but set by what? Is it set if the value loaded into bl is 0? Or is it looking way up at the mpy to see if that equals zero?
Old 12-27-2009, 01:46 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Phil, et al,
This thread has definitely been interesting reading Any thoughts on the end result of all this hard work? Is it realistic to think that it will be the ability to reprogram (flash) our stock ECU like the WRX/STi folks can?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-27-2009, 05:41 PM
AFAIK you cannot "flash" these ECUs like the OBD2 ECUs. You can build a board and burn chips as Phil describes on his site. Most of the useful parameters are documented and can easily be changed and burnt to a new chip. I am trying to analyze the code using the information others have already found as a starting point. I hope to understand some of the finer points of the program.
Old 12-27-2009, 06:46 PM
b3lha's Avatar
Phil & Belha
Originally Posted by SVXRide View Post
Phil, et al,
-Bill
I don't think there is any definite target as such. I think it would be great if we could uncover enough information about how the ECU works that technically skilled owners could have a go at tuning their cars themselves.
It is definitely realistic. We are actually really close to that point right now. We have a well-tested memory adapter design. We know where to find the fuel and timing maps and approximately how they work. All that's really needed is for somebody with tuning skills to fiddle with those maps and log the results and prove that they do work the way we think they do.
So many people have contributed to this thread and I'm amazed at the amount of good stuff has come out of it, directly or indirectly:
* An interface cable for connecting a PC to the car.
* Software that can display and log the ECU and TCU data.
* The locations of the parameters in the ECU and TCU.
* The TCU pin A4 power mode mod for USDM cars.
* The TCU software power mode mod for Euro/Aussie cars.
* A collection of ROM versions from different years and markets.
* A document showing the tuning differences between markets.
* A method for chipping the TCU.
* A daughterboard to adapt the ECU for modern eeproms.
* Decoding the TCU shift and torque converter maps
* Decoding some of the ECU maps
and finally, on a personal note,
* I got a full time job cracking ECUs.
That's just off the top of my head. There's probably a load of other stuff I can remember right now. And it doesn't include stuff outside the SVX world. I regularly get emails from people thanking me for information they've taken from my website and used for their own projects.
I'm particularly pleased that we cracked the TCU. I think we were the first people ever to crack the subaru TCU. In fact I've never heard of any car club cracking a TCU before.
I just wish I had more time to devote to it. I now have a two year old daughter and a 2 month old son, that I didn't have when I started this thread.
Old 12-27-2009, 06:55 PM
b3lha's Avatar
Phil & Belha
Yeah, don't get me wrong. You can't "flash" these ECUs. They are too old. Flash chips were not available when these units were designed. To modify the ECU, you modify the rom file, burn it into two chips, plug them into the adapter and then plug the adapter into the ECU.
It's not hard to do, but it's not quite as easy as just hooking up a cable like the WRX guys do. In some ways it's better. The flashable ECUs can only be flashed a certain number of times and then they die and they're expensive to replace. With ours, you can replace the chips as often as you like.
(I suspect the OBD2 SVX ECU may be flashable, but I've never seen one and I don't know for sure one way or the other).
Old 12-27-2009, 07:12 PM
b3lha's Avatar
Phil & Belha
Yes. It's setting a minimum value of 0 to A. ie. Following the subtraction, if A has become negative, set it to zero.
The Z flag gets set if zero is loaded to bl. I think this code wants to end up with a number between 00 and FF in AL. If BL is not zero (ie. the result of the calculation is >= hex 100) then it sets AL to the maximum value of FF.
Old 12-27-2009, 09:04 PM
SVXRide's Avatar
Yep, I understand you can't flash our ODB1 ECU - in its stock condition I was hoping that maybe this was leading to replacing the ROM with a "flashable" version
-Bill
Phil,
Can't thank you enough for all the work you've done to date!
-Bill
