Old 04-27-2003, 08:46 PM
lee lee is offline
Question chime location ??
No warning for key in ignition when the door is open, or other things most cars "chime" in on.
I don't know if it just doesn't work, or was disconnected - has never worked since I bought the car.
Thought I'd start out at the part that's supposed to make sound - but I haven't got the foggiest of where that is.
If someone would be so kind as to point out where the box (or whatever it is) is located. I would appreciate the help.
Next, if it turns out not to have been deliberately disconnected, any ideas besides the normal and tedious electrical trace?
tia
Old 05-01-2003, 03:17 PM
I just spent about 15 mins looking through subaruparts.com for that part but came up unsuccessful. I'll have to hunt down the sound in my car and let you know where it's located.
p.s. bump
Old 05-02-2003, 06:46 PM
lee lee is offline
bump for myself
Anybody want to look dumb moving their head around inside the car with their keys in the ignition and door open - then report that back here - so I can find out where to look for the box that makes sound?
Actually, a new thought came to mind - what does the stock system sound like - gentle chime, or obnoxious whatever? Maybe I shouldn't try to fix this.
Old 05-03-2003, 03:24 PM
I never hear mine because it's almost instinctive that I remove the keys from the ignition before I open the door.
Old 05-03-2003, 03:56 PM
Green1995SVX
I'm pretty sure it's in the center console under the e-brake handle. I can see something through there that has a little 'grate' on it and it has a lable that indicates it is a chime or buzzer of some kind. I'll look again later.
Mike
Old 05-03-2003, 04:01 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
That thing is suppose to make some noise?
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 05-03-2003, 07:03 PM
Don't bother fixing it
Originally posted by lee
bump for myself
When you find it, tell me so I can rip it out. It would have to be the most anoying thing about the car. You can't have the key in the acc. position with the door open and the sound system on without that damed chiming sound.
I just have to turn my hearing aid off. The frequency is too high for me to trace, seems to come from every where.
Old 05-03-2003, 07:07 PM
You might be right. I sat for about a minute during my lunch trying to track down the source of the noise.
As for how it sounds, it's a repetitive beep lasting for approx 1/3 second with a 2/3 second pause between beeps.
Old 05-03-2003, 07:24 PM
lee lee is offline
thanks one and all. I will look for it and give it a try.
