Old 06-25-2011, 11:10 AM
The Molinator
Power Steering ..SqUeeAlL.. ?
My PS unit is working at about 98% now after O-ring and fluid change!
But why do I get a 5 to 10 sec squeal when starting up after long park.. .
Thats the only time! Never squeals any other time.. turning sharp.. or ?? Belt is tight.. . Hmmm?
Thanks..
Jim
Old 06-25-2011, 11:35 AM
Re: Power Steering ..SqUeeAlL.. ?
Maybe the belt is old and slick and it softens up when it gets warm? I'd change the belt if it bothers you.
Old 06-25-2011, 12:50 PM
The Molinator
It was an old.. NEW belt! [2 to 5 yo in my parts box.. Is dat a prob?] Ha!
Think it was a cheaper ($10) belt .. as opposed to a luxury option belt @ $16+ >> Afraid to tighten TOO much.. just guessing.. but very tight!
Doesn't bother me too much .. cuz SO MUCH BETTER THAN BEFORE O-RING/FLUID SWAP! But Yes.. A little embarrasing to turn heads repeatedly.. Ha!
Thanks..
Jim
Old 06-26-2011, 07:55 AM
immortal_suby's Avatar
Thread Killah
Try tightening it just a little bit more....
Locker Link
2015 BRZ Limited 6MT
Old 06-26-2011, 08:59 AM
Try a different (old?) belt. Some belts do not make proper contact with the pulley. Sometimes the grooves are not deep enough in the belt. I've seen it once before.
Old 06-27-2011, 02:34 PM
The Molinator
Ya know.. I just worked on my SVX yesterday.. to flush coolant. I noticed a clicking (instead of squealing) when running engine to heat/flush coolant. I put stop-squeek on the AC belt (which looked a little loose) .. and it stopped the clicking sound!
Hoping it's that belt! Will know today after work.. about 90 degrees here. I think the heat of sitting in high temps causes the AC to stress at first when starting up??? causing that belt to slip???
I'll know at 8 pm tonight when I get off.
Thanks..
Jim
Old 06-30-2011, 03:39 PM
The Molinator
Yep! Dat was it! NO MORE SQUEALING! Hmmm? I was blaming the wrong belt!
Thanks..
Jim
