Old 06-16-2011, 02:46 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
stripped motor mount nut!!
im in a bind! i got a stripped motor mount nut, the middle one that goes through the rubber grommet. the head is stripped, i got a set of the snap on sockets that are for stripped nuts and bolts but there just rounding it off more. i have never had one of these motors out and was wondering if i could just tourch it off and put a new nut and bolt through?
thanks, bobby
Old 06-16-2011, 04:26 PM
Cam Cam is offline
Re: stripped motor mount nut!!
If you are replacing the motor mounts just use a drill bit the same size as the stud and drill straight into it, in the center, until there is no bolt left for the nut to hold onto.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 06-16-2011, 05:13 PM
use a pencil die grinder to cut most of the way through one side and then hit it with a hammer and chisel at the week point. it will most likely break, or at least loosen up enough so you can rotate it off by hand. if the rounded nut sockets round it more it is probably pretty soft.
